Old 07-22-2013, 07:43 PM   #1
drmiller1
77 cluster circuit board fit 76 too?
Hey There,
I have gauge cluster that appears to be close to my original (76). The only thing I see different is the 4 wheel lock light. I need to know if it is a go or not. If no as is, what changes need to be made. My original is very rough, most mount tabs are broke, no lens, and faded dirty gauges. The replacement is a 77? k truck unit maybe. I'm not sure, info I have found is not too clear.
any help would be greatly appreciated.
Nothing better than an old truck...
76 C-10 Silverado
92 Silverado Z71
drmiller1 is offline   Reply With Quote
Old 07-22-2013, 09:23 PM   #2
motornut
78K & 79C Jimmys
motornut's Avatar
Re: 77 cluster circuit board fit 76 too?
So the 4X4 light is just a bulb to put in?
my K78 and later ones have a seperate plastic socket for 4X4 hole
your arrow appears to show it move spots ?
my K78 has a choke light next to the 4X4 but it's not even opened/drilled for use
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
Old 07-22-2013, 10:06 PM   #3
drmiller1
I'm not sure on the bulb ,it appears that way. My truck is 2wd. I was thinking at worst, swap speedo's and be done.
Best case scenario, drop cluster in and go.
76 C-10 Silverado
92 Silverado Z71
Old 07-22-2013, 11:03 PM   #4
motornut
78K & 79C Jimmys
motornut's Avatar
no it dosnt move
just leave the socket empty
it can be left out for a two wheel drive
just not sure if the oil pressure and temp gauges measure the same
could meter them for ohms
John
Old 07-24-2013, 06:03 AM   #5
drmiller1
I have confirmed it is a 1977 K cluster. I just swapped housings and gauges, kept my 76 circuit board.
76 C-10 Silverado
92 Silverado Z71
