Box tail light panel? Does it bolt on?
I am out of town for a few days and was just wondering the rear panel on the box that houses the tail lights on these trucks is spot welded or bolted on? Thanks!
Posted via Mobile Device |
1961 crewcab
Re: Box tail light panel? Does it bolt on?
it is spot welded on.
60 build: http://67-72chevytrucks.com/vboard/s...d.php?t=280904 61 crew build: http://67-72chevytrucks.com/vboard/s...d.php?t=646830 63 build: http://67-72chevytrucks.com/vboard/s...d.php?t=336537 64 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=448681 65 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=590715 65 build: http://67-72chevytrucks.com/vboard/s...d.php?t=281955 |
Ok thanks are they tough to get off without wrecking them I am you g to give it a try.
1961 crewcab
yes, my suggestion is to leave it if it does not need to be replaced, the only way to get at the spot welds is to destroy either the bedside, or the rear panel.
people have said the best way to re- install the aftermarket repro, or a good o.g. panel is to use panel bonding adhesive.
