ok guys i got a '86 lwb 1/2 ton and am currently waiting on my NEW rims to get here from LMC....
i ordered these wheels below (15x10) all 4 same size.... i was needing to know what the best size tire is to run on these with a 4.5"/6" drop??? ![]() ![]() ![]() ![]() ![]() Posted via Mobile Device
KAOTIK Kustumz 1984 Chevy 1 Ton Crew Cab Dually "Western Hauler"454, th400, (6.0, 4l80e Swap Coming Soon)(5/7 Drop Coming Soon) (ON HOLD FOR NOW) 1986 Chevy 1/2 Ton LWB Silverado350, 700r4, (5.3, 4l60e Swap Coming Soon)(4/6 Drop) |
Re: ? bout tires for my '86 lwb....
I've got 245/60r15 for the front, and 275/60r15 for the rear on mine. About a 5/7 drop on my truck. I had 255/70r15s on before but the tires were hitting on the lip of the fender in the front.
1983 Chevy lwb: 400 sbc destroked to 377, comp cams xe 268, Holley Street Dominator Intake, Holley Street Avenger 670 cfm, headers, flowmasters. SOLD 1998 Trans am, mostly stock with magnaflow catback My build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=454329 |
#3 | |
They're 15x8 all around
Ya see bro mine are gonna be 15x10 all around....
I'm thinking of going with 295/50-15 all around Posted via Mobile Device
I checked your tire sizes and...
245/60-15 fronts are 26.6" tall 275/60-15 rears are 28" tall I then checked the size of the tires I'm thinking bout running... 295/50-15 all around are 26.7" tall So they would be basically the same height as your fronts but all around and be quit a bit wider than yours... Yours are 8.5" tread width Mine are 10.4" tread width Posted via Mobile Device
I think 275/60r15s would look good all around.
Did you know Kaotik that the important measurement is the backspacing on your new rims. That determines how far to the outside the edge of your tire sits.
While your tread width on your 295's is indeed 10.4" your cross section width (total width) on 10" rims will be closer to 12". Since you already got the rims coming don't buy tires yet. Put the rims on the hub and then use a straight edge to see where the edge of your tire will hit the wheelwell lip. Here's a link for checking wheel/tire fitment. http://www.carcraft.com/techarticles...t/viewall.html |
