[Pix] Flip Kit on a C10 SWB
Here's a few pictures I went out and took just now. This is for anyone wondering if they can do a Flip Kit in the back and not have to C-Notch. (I just removed the factory bumpstop bracket) The space between the axle/frame UNLOADED is 4"...
Here's another picture, of the Shock Extenders...
It followed me home?
my kit (chassis tech) did not come with shock extenders? I wonder if I should have them?
Adam That's why they call it a shortcut Kyle, if it was easy it would just be the way. 86 c-10 SWB 85 CCSB 90 GMC K30 Crew SRW 1985 C30 Dually |
You get what you pay for
![]() Join Date: Dec 1999
No flip kits come with shock extenders. IMO, shock extenders are needed with flip kits. When doing a flip, the shock angle changes a lot. Adding extenders will get some of it back to a more proper degree, besides giving you more shock travel.
Mike 1985 Chevy C-10 |
www.73-87chevytrucks.com
I agree with swervin. My flip kit from a LONG time ago included them and I think they should include them also. Shocks should be mounted as close to 18 degrees as possible.
Chris Lucas 1973 Chevy C-10 1978 GMC Jimmy (2WD) - SOLD 1987 R10 twin turbo LS 1991 R3500 SRW CrewCab 1985 K5 diesel swapped project 1989 K5 2WD conversion w/ Vette susp Project Captkaos Customs 73-87chevytrucks.com |
LED King
Doesn't that change the axle angle too? Shouldn't there be a spacer for the transmission to correct the angle?
Tyler 1985 C10 305 w/ Bowtie OD TH700R4 3.42 LSD 202,000 miles 2006 Ford Focus ZX3 5-speed Stick 2016 Chevy Spark EV Gone: 2002.5 VW GTI 24v VR6 Gone: 2008 VW R32 |
#7 | |
Correct me if I'm wrong guys. |
Yes, and no. Typically you don't need to adjust the pinion angle on a flip. Most of the ones I have seen have the "engineered" the proper angle in there. I have had some people on the internet saying they needed shims, but I haven't. My pinion is usually around 3-4 degrees. You really don't want to change the angle on the transmission though, it will effect the engine/driveline angle. The pinion centerline and the drivetrain centerline should be parallel to each other for proper driveshaft phasing.
I've had the flip kit on my Silverado for a long while without the C-notch and have never bottomed out the frame, the only time it has was when I had to load the bed with a load of rocks for a garden project, flip kit is the way to go, oh and I also got the shock extenders with my flip kit.
guess I better get some shock extenders.
The full convertible guy
![]() Join Date: Jul 2001
I guess I better remove my bump stops AND get shock extenders lol.
Brad
2012 Kawasaki Vaquero (Lime Green) 2000 BMW 740iL 1995 Chevy ECSB riding on air 1975 GMC Jimmy 2WD lowered 4/6 1972 Chevy Trazer soon to be roadster 1965 Mustang 289/3 speed (friends dad bought it new) 1964 Chevy C10 (dad bought it new) |
Under construction!
Where did you get that DJM flip kit?!
2001 Silverado bagged on 22's. *Sold* |
i put the hangers only, but i also replaced the 3 leaf with 4 leaf. do yall think i need to do something about the pinion angle thing.
2004 Silverado Crewcab 1972 Chevy Monte Carlo 2017 Chevy Tahoe |
Jeff,
you only used the shackles, right? Dropping the rear of the leaf springs 2" really only drops the truck and inch or so. Not enough to worry about. Now if you did use hangers on the front, this will cause a weird pinion angle, IMO. I think I seen it somewhere, they tell you when you buy only hangers you might need to uses some shims to get the angle back right. |
#15 |
FYI: I bought a DJM 5" flip kit from Stylin'Concepts and it included the shock extenders. I think the kit cost me $89 plus shipping.
Mitch 1978 Chevrolet Silverado C 10 454 BB, TH400 |
#16 |
I lowered my 78 4/6 with a notched frame. I also had to shorten my driveline 1" jay
#17 |
The Western Chassis flip kit moves the axle back to take care of the driveline. It has an offset hole in the block for this purpose. Are you sure you put the block in the right way?
#18 |
LED King
Seems I opened a can of worms.
#19 |
hmmmmm i will have to check to see if the block is placed correctly. I allready had the driveline shorten 1".
#20 |
On my DJM kit, the hole was offset, to correct driveline angle. (To concur with Mike.)
