Old 12-17-2013, 06:09 AM   #1
merlin3
what type rear end?
is there a way to run the numbers from my axle housing to see what it is out of before ordering outer seals,bearings and brake shoes? it I am not sure it is stock,72 c10 2wd.thanks
merlin3 is offline   Reply With Quote
Old 12-17-2013, 09:39 AM   #2
LockDoc
The Older Generation
LockDoc's Avatar
Re: what type rear end?
If you think it has a '67-'72 rear, read this thread...
http://67-72chevytrucks.com/vboard/s...d.php?t=578793
LockDoc
Leon
Old 12-17-2013, 06:52 PM   #3
merlin3
thanks lockdoc.none of the numbers match up though.what does GM65 mean? that is stamped on the pumpkin on drivers side.the only stamp on the tube reads BMW247.
Old 12-17-2013, 08:03 PM   #4
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
Post some pics of the rear cover.
Gary
'cuz chicks dig scars...
I would never rebuild a 305.
Old 12-18-2013, 07:04 PM   #5
merlin3
the cover looks like this.thanks for the help.
Old 12-18-2013, 07:21 PM   #6
Fitz
That looks suspiciously like a GM 12 bolt 8.875P Car diff from a Chevy impala. The 8.875T Truck diff is a different shape. Contrary to the popular urban myth, the 12 bolt designation refers to the number of bolts that hold the ring gear to the carrier and has absolutely NOTHING to do with the number of bolts that fasten the cover to the diff housing. That was just evil humor on the part of the engineers who designed the 12 bolt diff to confuse the uninformed, the gullible and the BS'er.
Fitz is offline   Reply With Quote
Old 12-18-2013, 09:10 PM   #7
GASoline71
GASoline71's Avatar
I have explained that to some of my buddies many times, and they still think I'm pullin' their leg. Oh well. Just like one of my Ford buddies that calls BS when I tell him that the General made a Chevy 302.
Gary
Old 12-18-2013, 09:11 PM   #8
Fitz
Gary
It's so much fun making fun of the BSers and the Found On Road Dead guys, isn't it?
Old 12-18-2013, 08:19 PM   #9
merlin3
your right Fitz,definitely from a car mine does not have the mount for the track arm.i am wondering if this is going to be a loosing battle trying to find out what it is or should i just find a new unit [no used parts here].
Old 12-18-2013, 09:05 PM   #10
Fitz
The 8.875P is a strong diff. If you can weld, Currie sells loose housing brackets including the mounts you need for the Panhard bar. Installing these is probably an easier way to convert what you have to fit your truck. There are lots of diff shops here in Southern Arizona but there isn't one I would trust to weld those brackets on and for good reason. They simply have no stake in the outcome! If you tack them in after aligning everything at ride height then have a certified welder finish them that is the best way.
Old 12-19-2013, 07:37 AM   #11
merlin3
thanks for the help guys ,i think i have enough info to call Summit and order seals,bearings and shoes.
