01-14-2014, 10:01 PM | #1 |
door hinge bolt plates?
Is there anywhere that sells the plates the go inside the pillars that hold the door hinges? Really need a set. the ones I have been taped way to much and the bolt size I would have to go up to is way to large.
01-15-2014, 01:42 AM | #2 |
60-66 Nut
Re: door hinge bolt plates?
Do you need all 4?
01-15-2014, 07:26 AM | #3 |
No I just need 2
01-15-2014, 08:42 AM | #4 |
I only need 2
01-16-2014, 01:28 AM | #5 |
60-66 Nut
I probably have 2 good ones, I'll look and see.
01-16-2014, 08:12 AM | #6 |
Captianfab you would be a life saver. I really don't want to make these things.
01-15-2014, 01:42 AM | #7 |
get a piece of 1/4" plate drill tap install
01-15-2014, 06:46 AM | #8 |
Trique mfg. has them in stainless
01-15-2014, 06:53 AM | #9 |
Use a threaded insert such as a Recoil, E-Z LOK, or a Heli-Coil. With these you would drill the hole out larger, tap it and install a insert back to the original thread size.
01-16-2014, 08:32 AM | #10 |
I've had to make several over the years, really not that bad to do. Hardest part is getting them back in if the "cage" part is gone in the door post.
