Old 02-10-2014, 07:34 PM   #1
TexasLS1
TexasLS1's Avatar
Parking Brake Cable
My truck is a 72 SWB, and the PO had hacked the parking brake cable. I've replaced the the cables and hardware, but I was missing the 2 loops/guides that I assume would attach to the frame. I've seen them in diagrams in catalogs, but wasn't sure if they were only used on LWB trucks? Do I need them? Any pics of the cable routing on a SWB would be much appreciated.
I also need to find the brake cable lever that installs inside the driver rear drum, behind the shoe. Does anyone know of a source? Doesn't look like Brothers, GMCPauls, or LMC carry it. I'm thinking I might be doing some salvage yard searches...
TexasLS1 is offline   Reply With Quote
Old 02-10-2014, 11:10 PM   #2
leddzepp
Moderator
leddzepp's Avatar
Re: Parking Brake Cable
Car quest or napa will have the ebrake arm that you need.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
Old 02-11-2014, 12:01 AM   #3
TexasLS1
TexasLS1's Avatar
Ok that's good to know! I didn't realize those guys carried it. Thanks!
Old 02-11-2014, 09:14 PM   #4
70STOVEBOLT
70STOVEBOLT's Avatar
Napa does not carry that piece or the spring for it, I need one also. I don't know about carquest.
70 C/10 SWB 402/TH400/3.73 "The Needy Beast"
200,000 Mile Club
Disc Brake Club
Owner installed options:
Front Sway Bar
Power Steering
Power Brakes
Cigar Lighter
Courtesy Lights
Deluxe Side Markers
Wiper Delay
Sliding Rear Window
Power Windows
Power Locks
Sniper EFI
2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear
70STOVEBOLT is offline   Reply With Quote
Old 02-11-2014, 09:33 PM   #5
Andy4639
Old member
Andy4639's Avatar
Wink Re: Parking Brake Cable
I just cleaned my drivers side rear brakes today. Here is a bad picture of the cables and the rods you speak of.
The rod is right behind the crossmember.
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Old 02-11-2014, 10:48 PM   #6
TexasLS1
TexasLS1's Avatar
Thanks for the pic Andy!!
Old 02-12-2014, 07:39 AM   #7
Andy4639
Old member
Andy4639's Avatar
Your welcome,
I have it up on stands I will try and get some better pictures of them. All they are is slick rod with a circle hook on the end of it for the cable to ride in.
Old 02-12-2014, 08:45 AM   #8
Grumpy old man
Grumpy old man's Avatar
I have an extra long bed frame I will check it today and see if the parts you seek are there .
Old 02-11-2014, 10:47 PM   #9
TexasLS1
TexasLS1's Avatar
I checked the local car quest today but no luck. I think our best bet is to find someone parting out a truck or someone who's done a rear disc brake conversion who has the drum parts left over
Old 02-12-2014, 03:51 PM   #10
Andy4639
Old member
Andy4639's Avatar
Some better pictures of the hangers.
Old 02-12-2014, 04:02 PM   #11
TexasLS1
TexasLS1's Avatar
Awesome, that helps a lot since mine are missing. Thanks again!
Old 03-09-2014, 05:17 PM   #12
70STOVEBOLT
Did you ever find the lever? I found a GM part number for it: 3842980 if you do a Google search you will probably find one. Also, the GM part number for the spring is 1312281
200,000 Mile Club
Disc Brake Club
Front Sway Bar
Power Steering
Power Brakes
Cigar Lighter
Courtesy Lights
Deluxe Side Markers
Wiper Delay
Sliding Rear Window
Power Windows
Power Locks
Sniper EFI
Old 03-25-2014, 06:26 PM   #13
TexasLS1
TexasLS1's Avatar
Bringing up an old thread, but I'm realizing I need the spreader bar/ strut that's circled in red above. Were ya'll able to find this for the 1/2 Ton 11" drums? I can't get the part numbers to bring anything up and I'm not sure if the LMC part is correct for 1/2 Ton...
Old 03-10-2014, 10:44 AM   #14
TexasLS1
TexasLS1's Avatar
Thanks for posting the part #'s - I haven't gotten the strut or the spring yet. I hadn't thought about getting them, but maybe I need to??
Here's a pic from LMC of the lever you need in red, they have the spreader/lever/strut but have it listed for 3/4 ton trucks? Do we need it for the 1/2 tons?? They don't sell the spring, but found the spring through O'Reilly Auto Parts - they may even be able to get the strut/lever. The final part I'm looking for is circled in blue, the parking brake cable attaches to a notch on the bottom. I need to find it for the driver's side but have had no luck what-so-ever...
Old 03-10-2014, 11:53 AM   #15
quick60
quick60's Avatar
What rear end do you have? I found it at NAPA for my 3/4 ton with a Dana 60 ?
quick60 is offline   Reply With Quote
Old 03-10-2014, 12:31 PM   #16
70STOVEBOLT
Ah, I misunderstood which part you needed. Yes, I need the part circled in red. The part numbers I posted are for that part and the spring that fits over that part. I don't know where to get the part circled in blue. I will see if I can find out for you.
200,000 Mile Club
Disc Brake Club
Front Sway Bar
Power Steering
Power Brakes
Cigar Lighter
Courtesy Lights
Deluxe Side Markers
Wiper Delay
Sliding Rear Window
Power Windows
Power Locks
Sniper EFI
Old 03-10-2014, 01:01 PM   #17
TexasLS1
TexasLS1's Avatar
Mine's the original 1972 GM 12-Bolt (1/2 Ton). You were able to find the parking brake arm that the cable attaches to? Or do you mean the Strut with the rectangular spring?
Thanks for keeping an eye out for me! I'm glad you were able to find the parts you needed!!
Old 03-10-2014, 01:04 PM   #18
70STOVEBOLT
The part numbers I posted were for the strut and spring. Near as I can tell, the part numbers for the emergency brake levers that you need are 15594177 for LH and 15594178 for RH. Hope this helps.
200,000 Mile Club
Disc Brake Club
Front Sway Bar
Power Steering
Power Brakes
Cigar Lighter
Courtesy Lights
Deluxe Side Markers
Wiper Delay
Sliding Rear Window
Power Windows
Power Locks
Sniper EFI
Old 03-10-2014, 05:27 PM   #19
TexasLS1
TexasLS1's Avatar
Sir, you are a gentleman and a scholar!! I was losing my mind trying to track this down. I appreciate your help more than you know!
