Old 02-24-2014, 09:55 AM   #1
ddr11
ddr11's Avatar
Suburban grill swap
A little help here please I did the suburban grill swap on my 87 stepside this weekend, I got everything off the suburban for the swap including the wiring harness to to the fuse box. My problem is that the suburban wiring wont come close to plugging in to my fuse box which was for only two headlights. Am i missing something here or is it time to splice wires. Also my DA shut the hood to check alignment and i forgot that I hadn't hooked up the cable on the hood release yet, anybody no how to get the hood open? Am i going to gave to try any reach up from the bottom and unlatch it. It was late last night when i did this so I haven't really tried anything yet
ddr11 is offline   Reply With Quote
Old 02-24-2014, 10:50 AM   #2
nekkidhillbilly
Re: Suburban grill swap
2nd quest..........yes. 1st quest im not sure but i think you do need to splice stuff.
nekkidhillbilly is offline   Reply With Quote
Old 02-24-2014, 12:03 PM   #3
Cherub
Cherub's Avatar
on my 91 suburban conversion it was plug and play.... why it doesnt reach is odd. for the latch ive drilled a hole in the coresupport to hit the latch before.....
Cherub is offline   Reply With Quote
Old 02-24-2014, 12:07 PM   #4
ddr11
ddr11's Avatar
No its plenty long enough the accual plug end is way different
Old 02-24-2014, 03:07 PM   #5
mrolds88
If the plastic connector is different, the terminals may still be the same type. If so, you can simply pull the individual terminals and swap them into the old connector. Pretty sure the color codes would be the same.
72 GMC C2500 402/Th400 first truck (still have)
77 GMC C3500 CC dually Sold
70 C50 dump truck "Rusty"
87 K10 Suburban Sold
93 K2500 xcab 6.5TD
96 GMC K2500 Suburban 6.5 TD
mrolds88 is offline   Reply With Quote
Old 02-24-2014, 05:56 PM   #6
jitteryguy
GoatLube Experss
jitteryguy's Avatar
most people just splice thebtwo harness's, that's how I do all mine. I cut each wire at different spots so all the splice's are not together .
Goat Lube Express, locations in Qalat,Afghanistan & Clarksville, Tn.
'87 R30 dually 454/TH400
'85 1/2 ton CCSB
'92 S10 350/350
'84 MonteCarlo 383/PG/9"ford
'78 Malibu wagon 350/350
'78 Cutlass (project family car)
'96 S10 Jimmy (Moma's)
jitteryguy is offline   Reply With Quote
Old 02-24-2014, 06:14 PM   #7
ddr11
ddr11's Avatar
DO you use butt splices or heat shrink and solder? i would think the 2nd choice would be cleaner!
