Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The pre 1947 Chevrolet & GMC Truck Message Board
Old 02-25-2014, 11:52 AM   #1
solidaxel
solidaxel's Avatar
46 Door support??
The cross bar that is in the middle of the46 door has some hard foam looking filler to support the door skin, this needs to be replaced, what did you folks use to replace it with???
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
Old 03-18-2014, 12:57 AM   #2
tires2burn
tires2burn's Avatar
Re: 46 Door support??
Clean out the old foam and try to wipe with scotchbrite between the bar and door skin. Get a 2 part epoxy foam from a body & paint store called anti flutter foam. It will mix in the tube as you squeeze the gun and it will expand & fill the gap without pushing the door skin out. The foam in the rattle cans will push the sheet metal out and you won't be happy. Put a silver dollar size spot about every few inches and that will support the skin just fine.
tires2burn is offline   Reply With Quote
Old 03-18-2014, 09:38 AM   #3
solidaxel
solidaxel's Avatar
Anti-flutter foam, I will pick up some today
Thank You !!
LS 3 4L70E
Old 03-18-2014, 11:30 PM   #4
solidaxel
solidaxel's Avatar
I went to two paint supply stores this AM and all I could find was a 3M product called
"Ridged Pillar Foam" Two part epoxy, and it was like $45, and it said the expansion was 10X is that the material you were referring to?
LS 3 4L70E
Old 03-19-2014, 12:23 AM   #5
tires2burn
tires2burn's Avatar
I went to Terrys auto supply on the net and copied this. Its what you want. Your local shop should have it. This is used for roof skins, hood braces, anywhere you need to stop the flutter. It does not get hard as a rock & that's what you need.
3M™ NVH Dampening Material, 50 mL, 34274
Stock Number: 60455052450
Ideal 2-part urethane product for replacing factory NVH (Noise, Vibration & Harshness) sealants and foams. Can be used for large installations. Remains very soft, yet sturdy and will not degrade. 60 minute work time.
Product Description
•A high performance two component urethane adhesive.
•Replaces factory-applied NVH (Noise, Vibration & Harshness) sealants and foams. Remains very soft, yet sturdy and will not degrade.
•Use with 08190 Performance Manual Applicator and 38191 Static Mixing Nozzle.
Part #: 3M.34274
Price and Units
Units: EACH
Units: EACH
Weight: 0.50 lbs.
List Price:
$24.98 / EACH
Your Price:
$22.48 / EACH
Product Links:
MSDS
Add to your cart
Quantity
Old 03-19-2014, 09:00 AM   #6
solidaxel
solidaxel's Avatar
Thank You for the help.
LS 3 4L70E
Old 04-03-2014, 07:24 PM   #7
solidaxel
solidaxel's Avatar
Thanks I found some on Amazon and bought three tubes!
LS 3 4L70E
