Temp Gauge
Hey guys, I drained all the fluid out of my radiator because it was real dirty and brownish and the gasket was bad on the thermostat so I decided to replace the thermostat and put new fluid in the radiator. When I am driving the truck runs approx. 180-190 degrees but from time to time (mainly when I am coming to a stop) the temp jumps up to 260 degrees. I push in the clutch and rev up the engine and it jumps back down to normal temperature. What could be causing this?
http://67-72chevytrucks.com/vboard/s...d.php?t=580955 http://youtu.be/JYoQJYTXKqI 1984 Chevrolet Scottsdale C10 "Project Platinum C10" 1971 Chevrolet Chevelle "Project Car" |
![]() ![]() Join Date: Jul 2002
Re: Temp Gauge
Are you running a fan shroud?
Sounds like at rest your not getting the air to pull thru the radiator.
Re: Temp Gauge
It's all stock. Are you talking about the aftermarket fans that mount to the radiator?
Re: Temp Gauge
No I meant the factory one that fits behind the radiator and wraps around the fan
Re: Temp Gauge
Oh ok, yeah my truck has that.
Re: Temp Gauge
Fan clutch failed? Or maybe an air bubble?
Throwing out suggestions.
'86 C-30 dually, 454/tbh400 '73 K-20 350/350/205 (sold ![]() I'm kinda like duct tape- no real purpose, but handy to have around. |
Re: Temp Gauge
Bad water pump? Maybe the impelled is trashed and only flows enough when at a higher RPM or moving. Also check your thermostat. It may be sticking?
Re: Temp Gauge
Someone suggested that I start by loosening up my radiator cap and driving for a short time. If that didn't fix it then have Autozone check my cap and or replace it. Then look into changing out my water pump.
Re: Temp Gauge
I would double check that the temp gauge is reading correctly first.
How many blades does your fan have? IIRC some have 5 and other have 7. How quickly does the temp rise at idle? |
Re: Temp Gauge
Several years ago I bought a radiator cap with a built in temp gauge in it. That way I can double check my temp and compare to my gauge. It has come in very handy.
