04-18-2014, 04:00 PM | #1 |
98 Blazer leaning out at full throttle
I am so ready to go nuts ! I have 98 blazer that leans out at full throttle but if you lift a little it start pulling again. When you give hard throttle the O2 sensors voltage drops to 0.492 showing it leaning out . I have no vacuum leaks I Just replace intake gaskets my fuel pressure is 60 lbs. and does not leak down . Here the weird thing after I stop and put gas in it when I start it up it try to died when I pull back on the road. So does anyone have any idea what wrong ??? Thank !
04-27-2014, 02:05 PM | #2 |
Re: 98 Blazer leaning out at full throttle
You have fuel pressure but what about volume? Maybe kinked fuel line or blocked tank pickup.
04-27-2014, 03:19 PM | #3 |
blood type; Retumbo
.492 is not lean, it's mid-range.
Man rule #77...if you own a 67 stepside with a caddy 472 you will never be in danger of loosing you man card |
04-29-2014, 11:57 AM | #4 |
When monitoring oxygen sensors, you need a scanner that will graph, not just a scanner that will give you a number. Did it do it before you replaced intake gaskets? Is the check engine lamp on? Any Codes?
