Drip rails
The PO on my junk shaved the drip rails. I was wondering if anyone had ever put them back on a truck after they were removed. I am not sure what all is involved, just wondering.
77 C10, 6.0LS/4L80E, 3:73 12 bolt. Boss 338's 20" x 10" w/ 285/50/20 rear. 20" x 8.5" w/ 245/40/20 front. Vintage Air. Full Autometer gauges recessed in factory bezel (Thanks bigblock73!) Gm Storm Grey Metallic paint "Cool ain't ever cheap and cheap ain't ever cool" |
Re: Drip rails
On my year you could just re-drill the holes, and install.
I think 73-77 were this way as I know 73-74 were this way so you could score an early set. |
Re: Drip rails
I know my '83 had them held on by screws. Just re-drill the holes and you should be good to go.
Steve Member of the Foot Pedal Club '83 Chevy K20: 6" Rough Country, 3" Performance Accessories BL, Bushwacker Cutouts, 38x15.50 Mickey Thompson Baja Claws, 350 HP 350 crate engine from Jegs, Turbo 400 ![]() |
Re: Drip rails
How do they come apart so you can access the screws?
Re: Drip rails
The chrome is just a cover that clips on. Kinda pita, but do-able.
Had a set on my '73 (not stock), I removed them, 1 snowstorm and they went back on. Oh, if you get the chrome off, the steel underneath has cut outs to get fasteners in and out,
'86 C-30 dually, 454/tbh400 '73 K-20 350/350/205 (sold ![]() I'm kinda like duct tape- no real purpose, but handy to have around. |
Re: Drip rails
mine were shaved, i redrilled and put them back on
"DON'T TOUCH THE TRIM!!"-Early Kyler |
Re: Drip rails
So you just pry them off?? Or slide them off?? Don't want to destroy them.
Re: Drip rails
You don't have to remove the chrome/stainless piece to get to the screws. I have had mine on and off without doing that. Finding the right screws was kind of a pain. I finally found some stainless screws at a local hardware store that were perfect. Before I found those everything I found in the correct size for the holes were too long.
Re: Drip rails
they are all screwed on, you dont have to remove the chrome to install them
Re: Drip rails
My next question is, are the ones sold in LMC's catalog the entire drip rail or just the chrome trim?
Cruzzzn' Vet
Re: Drip rails
I'm partial to the shaved look
Re: Drip rails
Mine I removed in one piece, they just kinda became separated on the ground. I installed in 2 pieces as I could get a straighter shot at the screw.
Odds are, they came from a junkyard, who knows when. Besides, it was a plow truck-work truck, not a showpiece.
![]() Join Date: Mar 2013
Re: Drip rails
I used a small wrench to remove them from the truck. I did not want to bend the stainless either. Also, get you some stainless screws from the hardware store, they look cool. And dont forget the 3m double sided tape. This is what actually keeps the water from running thru them.
![]() Join Date: Oct 2005
Re: Drip rails
The shaved look I.M.O. makes the cab look like a new style truck and not vintage.
![]() Plus, the shaved cab allows water to flow DIRECTLY into a crack open window during rain or if you use your windshield washer.
1972 C10 SWB, 1970 Corvette, 2017 Grand Sport |
#15 |
Re: Drip rails
#16 |
Re: Drip rails
Like Donut said its just a metal frame piece that bolts on with very roughly 8 screws or so in each side, and a small chrome trim clips on it almost flush - you can put the chrome trim on first then just screw the whole deal in with a small wrench which takes forever as no room and you cant use the closed end of the wrench like with a gear wrench, only enough room for open end doing like half a turn at a time so yeah real pain.
But yours being shaved could be a problem, like how far did they hammer each of the roughly 8 holes in before they welded or bondo'd them? if they're pounded in half an inch and bondo'd, then what - use longer screws with old indented holes? Or just move rail over some and tap all new holes in metal? Its not going to be easy with so many holes filled in. |
#17 |
Re: Drip rails
I reattached mine. I got some from the junkyard and bought new stainless screws and attached them with 3m tape and some gasket adhesive over the screw holes so water doesn't get in.
86 c30 crew cab dually 454/400 4/6 drop SOLD 1-8-11 1981 chevy K10 short Bed Scottsdale SOLD 10-26-2020 67 GMC Stepside Straight six/3 on the tree "The Peach" 2020 Silverado Double Cab LT Z71 5.3 8 speed Daily Driver K10 build http://67-72chevytrucks.com/vboard/s...d.php?t=671934 The Peach build http://67-72chevytrucks.com/vboard/s...d.php?t=733903 ![]() |
#18 |
Re: Drip rails
I welded the holes up on mine when I repainted . I did not want to re drill the cab so I reattached with 3m tape to the cab . Staying on just fine , but you must be sure they fit the cab perfect at relaxed state . So I just keeps tweaking them until they fit and then added the 3m tape .
#19 |
![]() ![]() Join Date: May 2015
Re: Drip rails
I left my holes when I repainted and when I put the drip rails back on I put a bead a black rtv on the backside and then screwed em back on..after it dried I cleaned up excess rtv
#20 |
Re: Drip rails
Thats not a bad idea, are you saying you ran RTV down the entire back of the drip rail frame or just on the screw holes to seal them? Are the drip frames known to leak a little?
#21 |
Re: Drip rails
Matt, if you used 3M tape then what did you use the screws for, or did you do both?
#22 |
Re: Drip rails
I ran the very small bead of rtv (it squishes down flat) the entire length of the drip rail..there was very litlle cleanup..most of what squirted out just pulled right off
#23 |
Re: Drip rails
Okay, yeah I'm gonna try this too - hadn't even thought of it but seems like a good idea to keep water and rust out from under that frame rail - thanks.
#24 |
Re: Drip rails
I did both, they did not go anywhere after that haha. My truck is at the painter and he told me he had a hell of a time getting them off.
#25 |
Re: Drip rails
