Lay rocker or lay door.... Need your vote
I'm debating cutting the rotted rockers off my panel truck. The frame was 8" tall under the can being a 1ton. We added 3x5 box to the frame. We cut an inch off the bottom of the frame so it's level and then took 2" off the top of the frame under the cab. At this point I already have to redo the floors anyways because of rot. If I body drop it another 2" roughly I can basically lay door. My only concern is at that point I need to drop the frame horns down about 4"s. Also have to cut off the rear 4"s.
Besides the steering (which I have to redo anyways) what other issues may I run into. Plan on just running some 15s with 75 series tires. I get roughly 13" of lift in the front. I don't want to run into hood issues. So I need your vote. Lay rocker or door here's some pics. |
Senior Enthusiast
Re: Lay rocker or lay door.... Need your vote
From a practical standpoint it seems like it would be better to keep the rockers, so the bottom of the doors wouldn't be torn up by the pavement when the chassis is laid out, and someone wants to get in or out of the vehicle.
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502 |
I plan on putting some strapping under the door so it won't actually sit on the door. Probably 3/16 or 1/4 strapping.
IMO, it just won't look right without rocker panels.
65 C20 292 4spd 4:56 Eaton HO52 |
I say keep the rockers....just my opinion....
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual http://67-72chevytrucks.com/vboard/s...d.php?t=519869 1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide http://67-72chevytrucks.com/vboard/s...d.php?t=619024 1964 Short bed trailer |
Keep'em rockers.
http://67-72chevytrucks.com/vboard/s...d.php?t=581873 The low buck build threads. Check'em out! http://67-72chevytrucks.com/vboard/s...d.php?t=666022 My build thread Crossmembers CC |
lay door! never seen it done before and you could be that guy. plus who wants to replace rust when you could drag it off.
Projects: 66 gmc, SWB ,BBW,76 disc brakes/PS and rearend, pancaked crossmember 2 1/2" drop spindles 1 cut coil, 6" drop coils 2 " blocks c-notch with a 350. |
#9 | |
Keep the rockers. Vehicles just don't look right w/o them. Make them shorter if you just have to be that much closer to the ground.
![]() Join Date: Mar 2013
Keep the rockers.
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643 1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056 My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw |
That's what I thought I had before. I'm probably wrong. I'll check it again later. I just have some airlift 2600 bags
