Old 05-14-2014, 11:55 AM   #1
solidaxel
solidaxel's Avatar
Uppwe A/C mounts for LS
I am looking for some pics of upper A/C mounts.
I have Dirty Dingos and they will not fit in the area between the inner fender.
I can not use a lower mount and I do not want to go with a whole new front runner system.
This is on a 5.3 truck engine.
We changed to a 2010 Camaro pump but that did not work out with alignment of crank shaft and power steering pump, so went back to the truck pump
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
Old 05-14-2014, 12:23 PM   #2
solidaxel
solidaxel's Avatar
Re: Uppwe A/C mounts for LS
Sorry that is the UPPER mounting bracket !!
LS 3 4L70E
Old 05-14-2014, 03:14 PM   #3
Wasted Income
Boosted Member
Wasted Income's Avatar
http://www.kwikperf.com/lsx_high_mount.html
1972 2wd K/5 Blazer Turbocharged 370 LSx - 941 rwhp / 1093 rwtq
1969 Chevy K-10 L33 5.3 / 4L80E / NP241 / 4" lift
1964 Buick Skylark Twin TURBO 383 LS pro-touring project
2014 VW Passat TDI - Daily Driver
Turbo diesel
2015 Sierra Denali HD Duramax Turbo diesel
2023 Ford Explorer ST - Twin Turbskis
2023 Ford F150 RCSB - Whipple Supercharged
2017 Polaris RZR Turbo
2014 Nor-Tech Center Console - Twin Supercharged Outboards
TURBO ALL THE THINGS!!
Wasted Income is offline   Reply With Quote
Old 05-14-2014, 03:57 PM   #4
solidaxel
solidaxel's Avatar
Originally Posted by Wasted Income View Post
Thank You, Ithink that one will fit the area we have to work in.
The Holley bracket extends too far into the inner fender area of the 46 Chevy pick up just like the Dirty Dingo one we have, which will be up for auction as it will not fit this truck
LS 3 4L70E
Old 05-14-2014, 03:34 PM   #5
chevyguy_72
Vintage Evil
chevyguy_72's Avatar
I have this one:
http://www.holley.com/20-134.asp
Havent installed it yet so the website is the best pic I can find...
chevyguy_72 is offline   Reply With Quote
Old 05-16-2014, 07:27 AM   #6
fastpace
Originally Posted by chevyguy_72 View Post
I have this one:
This is the same bracket that I have, it looks great and was easy to install just make sure you order the right mounting hardware for your motor. Some pics of mine on a 2011 5.3
1972 C10 LWB Highlander Dark Olive/White - Work in progress 5.3/6L80e, Accuair e-level, Porterbuilt Stage 1 front and Stage 2 rear, Wilwood 14"F 13"R, Vintage Wheel Works V40 18x8/18x11, and more... Build Thread
fastpace is offline   Reply With Quote
Old 05-14-2014, 04:15 PM   #7
solidaxel
solidaxel's Avatar
It looks like yours is a 5.3 truck LS correct?
Did you have to change the truck P S and alternator bracket?
Did the bracket come with a tensioner/ideler?
The water pump looks to be a truck, but the instructions say you need to use Camaro what am I seeing in your picture?
Sorry for all the questions, but I do not want to duplicate any more parts that do not work !!
LS 3 4L70E
Old 05-15-2014, 09:43 AM   #8
Wasted Income
Boosted Member
Originally Posted by solidaxel View Post
It looks like yours is a 5.3 truck LS correct? YES
Did you have to change the truck P S and alternator bracket? NO
Did the bracket come with a tensioner/ideler? YES
The water pump looks to be a truck, but the instructions say you need to use Camaro what am I seeing in your picture? Stock GEN 3 truck water pump
Answers in RED
Turbo diesel
Old 05-15-2014, 01:56 PM   #9
solidaxel
solidaxel's Avatar
Answers in RED
Well I guess I will put in a order, thanks for the help!
LS 3 4L70E
Old 05-15-2014, 02:01 PM   #10
solidaxel
solidaxel's Avatar
Answers in RED
Which power steering pump did you use, the Saganaw or the two part pump?
LS 3 4L70E
Old 05-15-2014, 03:31 PM   #11
Wasted Income
Boosted Member
Stock LS 2500HD pump.
Turbo diesel
Old 05-15-2014, 04:38 PM   #12
solidaxel
solidaxel's Avatar
Does your PS pump have a remote resevor?
LS 3 4L70E
Old 05-15-2014, 10:12 AM   #13
chevyguy_72
Vintage Evil
I was thinking the truck and 10+ Camaro units had the same front spacing.... just the alt/ps bracket is different...
Old 05-15-2014, 02:14 PM   #14
Hart_Rod
Hart_Rod's Avatar
You are correct.
Hart_Rod is offline   Reply With Quote
Old 05-15-2014, 02:37 PM   #15
solidaxel
solidaxel's Avatar
Originally Posted by Hart_Rod View Post
You are correct.
Don't forget the water outlet is in a different location
LS 3 4L70E
Old 05-15-2014, 02:48 PM   #16
chevyguy_72
Vintage Evil
That could be... just meant pulley alignment wise...
Old 05-15-2014, 03:54 PM   #17
bpatrol
the 2010 Camaro pump should be an ideal fit if everything else is stock truck acc.
is your truck motor a vvt motor? if so you wil need the l99 Camaro pump not the ls3 pump.
bpatrol is offline   Reply With Quote
Old 05-15-2014, 04:07 PM   #18
Hart_Rod
Hart_Rod's Avatar
The 2010+ Camaro pumps are the same LS3 or L99. The only difference is the timing cover and harness.
Old 05-15-2014, 05:00 PM   #19
solidaxel
solidaxel's Avatar
Perfect!, I was hoping it was the saganaw, thanks
I did not know if the 2500 and the 1/2 ton were the same
LS 3 4L70E
Old 05-16-2014, 01:16 AM   #20
Andy4639
Old member
Andy4639's Avatar
Talking Re: Uppwe A/C mounts for LS
Here is my LS1 bracket on the 6.0.
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Old 05-16-2014, 09:16 AM   #21
Wasted Income
Boosted Member
The only difference is that most (all?) of the 2500 pump are hydroboost pumps. They are externally the same, except for a 2nd oil return to the reservoir.
Turbo diesel
Old 05-16-2014, 10:05 AM   #22
solidaxel
solidaxel's Avatar
My 5.3 in my 78 has a second return line, I wondered what that one went to!
LS 3 4L70E
Old 05-16-2014, 09:03 AM   #23
solidaxel
solidaxel's Avatar
Well from the pic, the Holley will not fit between the inner fenders on the 46 Chevy, thanks
LS 3 4L70E
Old 05-16-2014, 09:20 AM   #24
Hart_Rod
Hart_Rod's Avatar
Those aren't Holley brackets, these are:
Old 05-16-2014, 09:25 AM   #25
fastpace
The pictures I posted are the Holley AC bracket, I just stayed with the original alternator bracket.
