Old 05-30-2014, 04:13 PM   #1
MountainGoat1966
84 K10 Lighting problem, this is weird
I did the search thing and all I found was advice to check ground connections.
Well, I did that and verified all bulbs and connections.
Here is my 84 K10 lighting issue, turn on parking lights or headlights, and the left turn dash indicator bulb glows bright. Left turn bulbs won't blink if the turn signal switch is connected.
I disconnected both connectors coming out of the steering column, eliminating the turn signal switch from the circuit, and I still get the left turn indicator glowing when the light switch is pulled out.
I was always taught to test, don't guess, and I can't afford to start replacing parts left and right in hopes of curing the problem.
How or what do I do next? Is it possible I have a bad headlight switch causing the issue ?
"Off the grid and on the seven day weekend plan"
"One person cannot know everything, but between all of us, there isn't much we don't know."
MountainGoat1966 is offline   Reply With Quote
Old 05-30-2014, 04:31 PM   #2
willett
Another Day, Another Dollar
willett's Avatar
Re: 84 K10 Lighting problem, this is weird
Grounds is the obvious first thing as you know. How's your under dash ground? (Big spider above e brake cable)
How's your flasher? Those can do weird things sometimes when they go.
Headlight switch shouldn't be more than about $15. Try that if all else fails
-78 K20 Cheyenne 454 long box, 4" lift, 35" MT's, '84 cab, '80 box
"its hip to be square"
willett is offline   Reply With Quote
Old 05-30-2014, 06:55 PM   #3
MountainGoat1966
I had two spare headlight switches on hand, no change.
Also had flashers on hand, no change.
Thanks for the suggestions, though.
If I could get a complete OEM wiring harness for the truck, it would still be cheaper than taking it to a shop and pay a hundred bucks an hour for substandard work.
Old 05-30-2014, 08:49 PM   #4
MountainGoat1966
Here is another piece of the puzzle I just discovered, if I remove the bulb from the left front parking light fixture, the issue goes away.
Inserting a known good bulb, the issue returns.
I am thinking of placing the blame on the pass through firewall connector where the wires for the front lights go.
Old 05-30-2014, 10:34 PM   #5
dman1982
dman1982's Avatar
i had this same issue, it was infact a ground, it was the ground that goes on the fender well on the drivers side, it actually did it twice, the first time it was corroded and the second it came undone, not saying this is your problem but worth double checking
Sgt Dennis Heineman
USMC Aviation Ordnance
I.Y.A.O.Y.A.S
2001-Present
84 K10
2000 trans am ws6
2011 nissan altima
2009 Troy Built with a 42 Inch Deck
My LS Swap http://67-72chevytrucks.com/vboard/s...=1#post6559371
dman1982 is offline   Reply With Quote
Old 05-30-2014, 10:51 PM   #6
MountainGoat1966
I looked for a ground on the driver's side fenderwell but found none.
I see a ground on the passenger side, and what seems to be a ground going into the firewall through connector.
Old 05-30-2014, 11:17 PM   #7
dman1982
dman1982's Avatar
I may have been wrong, it might be on the d/s core support
Sgt Dennis Heineman
I.Y.A.O.Y.A.S
2001-Present
84 K10
2000 trans am ws6
2011 nissan altima
Old 05-30-2014, 11:45 PM   #8
ray_mcavoy
^ I agree ... this sure sounds like a ground issue to me as well.
There should be 2 ground screws on the core support... one on each side. Start at the headlight connector and follow the wires back if you're having trouble locating one of them.
Since the ground wire on each side is shared by the headlight, parking light, and turn signal, there is still a connection between those lights even if the connection to ground (via the core support) is lost. That allows the head/park light on that side to find an alternative ground path back through the front turn signal circuit, causing the signal indicator on the dash to glow. Removing the bulb from the parking / turn signal socket breaks that alternative ground path.
ray_mcavoy is offline   Reply With Quote
Old 05-30-2014, 11:46 PM   #9
dman1982
dman1982's Avatar
Since the ground wire on each side is shared by the headlight, parking light, and turn signal, there is still a connection between those lights even if the connection to ground (via the core support) is lost. That allows the head/park light to find an alternative ground path back through the front turn signal circuit, causing the signal indicator on the dash to glow. Removing the bulb from the parking / turn signal socket breaks that alternative ground path.
Haha...also agreed!!!
Sgt Dennis Heineman
I.Y.A.O.Y.A.S
2001-Present
84 K10
2000 trans am ws6
2011 nissan altima
Old 05-31-2014, 12:16 AM   #10
buddy_1
buddy_1's Avatar
I would check to make sure that the bulb is an 1157 ( 2 terminal dots on the end ) first. I have seen people put an 1156 bulb ( 1 dot on the end ) in the socket and cause this problem. When an 1156 bulb is used in a 1157 socket, the single dot touches both teminals in the socket causing the feed back to the IPC indicator light. I also had a bad bulb in an old Nova when I was in high school cause the same thing. The park light element had broken loose on one end, bounced over and stuck to the turn signal element. If the bulb is good and correct check the socket for being shorted internally.
I know the "VOICES" aren't real but they have some great ideas.
1978 GMC Sierra Classic C25
1983 Datsun 280ZX Turbo
1997 Chevy Cheyenne K2500
1999 Polaris Sport 400
buddy_1 is offline   Reply With Quote
Old 05-31-2014, 08:20 AM   #11
Chevy3+3
This is good advice to check along with what others have said. I had a weird wiring problem with an 87' I had years ago. The turn signals were making my headlights blink on one side and some other crazy stuff. I found out it was a bad ground on the top of the drivers side radiator support. I regrounded the radiator support and jumped from it to another ground location which was the drivers side fender in my case. The crazy thing was......when the truck was having problems the grounds actually appeared to be good but when I ran extra ground wires and had multiple connection points the problems went away and never returned.
88' Chevy V30 3+3 4x4 Dually 454 TBI/NV4500/NP205
Chevy3+3 is offline   Reply With Quote
Old 05-31-2014, 10:48 AM   #12
motornut
78K & 79C Jimmys
motornut's Avatar
I've seen those headlight ground wires fried.
One reason , boosting from body as a ground, not engine/alt/batt.
Or the engine or other grounds gone .
That little wire becomes the path.
Check for brittle, baked too.
In fact my 78 had someone try to wedge it back in the ground plug.
Only found it by testing.
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
Old 05-31-2014, 12:53 PM   #13
hatzie
Moderator
hatzie's Avatar
I had the core support grounds do just that on a 79.
I was too hard headed to listen to an older friend that told me I had a ground problem. I chased it for at least a week.
GUESS WHAT... That old timer was right.
It was the RH ground set on the core support. The wires looked great. But. The wire was corroded almost off. The green powder went way back into the jacket. The only thing keeping the "wire" on the ring terminals was the strain relief crimp on the jacket.
The other thing that could do this is forcing an 1156 bulb into the 1157 socket...
1959 M35A2 LDT465-1D SOLD
1967 Dodge W200 B383, NP420/NP201 SOLD
1969 Dodge Polara 500 B383, A833 SOLD
1972 Ford F250 FE390, NP435/NP205 SOLD
1976 Chevy K20, 6.5L, NV4500/NP208 SOLD
1986 M1008 CUCV SOLD
2000 GMC C2500, TD6.5L, NV4500
2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263
2009 Impala SS LS4 V8
RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...Please include at least the year and model in your threads. It'll be easier to answer your questions.
And please let us know if and how your repairs were successful.
Old 06-01-2014, 10:02 AM   #14
cadillac_al
Sometimes I will run a separate ground wire from a signal light housing to a good ground if I can't find the problem right away.
76 Chevy K20
76 GMC K15
77 Chevy C10
77 Chevy K10
cadillac_al is offline   Reply With Quote
Old 06-01-2014, 12:17 PM   #15
MountainGoat1966
Okay, it looks like I am on to something here.
I grabbed my ohmmeter to test the ground connections from the socket to core support ground, and found a detail I had missed, the passenger side socket has the ground tab in it but the driver's side socket is missing that metal tab.
It's amazing such a tiny item can cause so much grief and headaches.
Gonna look in my spare parts box to see if I have a socket, otherwise will get one from the parts store Tuesday.
I will keep the thread advised if this cures the issue.
Old 06-03-2014, 07:27 PM   #16
MountainGoat1966
Problem solved !!!!!!!!!!!!!!
I spent 7 bucks and got a new socket, wired it in, and everything is fine now.
I don't remember ever changing the bulb, so how the grounding tab got broken off and went AWOL is anybody's guess.
This is one for my notebook, always inspect the socket closely to verify it has all its connections. And keep a spare socket in my parts box.
A hearty thank you to everybody who replied and offered help and assistance !!!
Old 06-03-2014, 09:35 PM   #17
motornut
78K & 79C Jimmys
motornut's Avatar
up here those tabs rust off
John
Old 06-03-2014, 10:31 PM   #18
MountainGoat1966
This is Arizona, we don't know what rust is, but at least our paint fades fast from the sun.
Old 06-04-2014, 04:53 PM   #19
hatzie
Moderator
hatzie's Avatar
I dip these bayonet & T15 bulbs in Vaseline or Silglyde. It keeps the sockets and bulbs A-OK.
