Old 06-15-2014, 08:07 AM   #1
NC67Chev
NC67Chev's Avatar
Sway bar questions
Finally getting around to installing a sway bar. Anyway, I have a couple quick questions:
1. It seems like 3/8 bolts are a little smaller than the original rivets. Is it best to upsize the hole for 7/16? Or, should I just use 3/8 and not worry about it?
2. I ended up with 1" lowering springs in the front. Would I be better off using factory height brackets or lowering brackets? Or, will it really not make any difference?
Thanks!
1967 Chevy C-10, 250 L6, Powerglide, 3.73, SWB, Fleetside
Upgrades: Power steering, Offset air cleaner, Rear Sport bumper, 3 point safety belts, HEI, -1/-2 springs, 16x5 wheels, McGaughy's disc brake conversion, Sway bar
NC67Chev is offline   Reply With Quote
Old 06-15-2014, 08:26 AM   #2
yuccales
yuccales's Avatar
Re: Sway bar questions
I just used 3/8" and they pulled the crossmember to the frame just fine, and have not come loose. Mines stock height so can't help you there. Glad your doing it, one of the best things we can do to these old trucks!
yuccales is online now   Reply With Quote
Old 06-15-2014, 10:04 AM   #3
chiefcfd
chiefcfd's Avatar
I have 2 1/2 drop spindles on mine. I used the stock height brackets with no problems.
1972 Chevy LWB Roadster
1999 Chevy Silverado 2wd
2015 Chevy High Country 4x4 Crew Cab
chiefcfd is offline   Reply With Quote
Old 06-15-2014, 10:36 AM   #4
michael bustamante
michael bustamante's Avatar
Your stock brackets will do just fine. Try to use a 1 1/4" or 1 1/8" bar. The original 7/8" bar doesnt seem to do much
1967custom
michael bustamante is offline   Reply With Quote
