Old 08-05-2003, 05:39 AM   #1
JREs69er
Question Tune Up Question
Hey guys, Wanted to get some opinions on tune up products. I had the truck emission tested today and it failed pretty bad for Hydrocarbs. Standard is 900 and I logged a 1333. I am planning on starting out with a tune up, plugs, wires, distributor, rotor, clean the carb, oil change, air filter, pcv. Anything else that I missed and any recommendations on what to use or not use as far as manufacturers i.e. bosch, ac delco, fram.
350/V8/4 barrel rochester/hei ignition
Any help would be appreciated.
JREs69er is offline   Reply With Quote
Old 08-05-2003, 06:47 AM   #2
wxman1
Do 67-72 trucks have to pass an emissions test
in Illinois? Is this recent? Or has it always
been that way?
Jim M.
Mt Juliet
wxman1 is offline   Reply With Quote
Old 08-05-2003, 06:57 AM   #3
A.P.
Black 72 Chevy
A.P.'s Avatar
In CA we don't have to smoge it. Just need insurance. But my needed the cat replaced inorder to pass the test.
A.P. is offline   Reply With Quote
Old 08-05-2003, 06:57 AM   #4
A.P.
Black 72 Chevy
A.P.'s Avatar
CAR
72 Chevy, SWB, 350engine, TH400
Old 08-05-2003, 07:56 AM   #5
JREs69er
Not sure if this is new or not. I know I received the test notice in the mail to have it tested. I believe they are a little less stringent on the older vehicles.
I have no catalytics on them. Did they have cats back in 1969? Running dual exhaust into glass packs put on by previous owner.
Old 08-05-2003, 08:46 AM   #6
wnc mountain
More hobbies than money!
wnc mountain's Avatar
They didn't start putting cats on them until the mid 70's. Maybe the person that was testing didn't know any better. But there is no requirement in NC.
'70 cst10/swb 350, 3 on the tree, factory buckets.
'70 GMC lwb 350/350 ps,pb
'72 c-10 lwb 350/350 a/c, ps, pb
'72 Blazer project
wnc mountain is offline   Reply With Quote
Old 08-05-2003, 04:17 PM   #7
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Onless your engine is getting worn, the tune up should help.
Taking a spray bottle of water and spraying a small steady stream into the carb with it running at about 1200 - 1500 RPM can help to knock some carbon deposits off of the combustion chaimbers, pouring small amounts of tranny fluid into the carb the same way can do it too, but personally i feel better with the water.
Make sure your timing is dead on, and replace your PVC valve too (I think 69s had them)
If the inspector says something about cats, then you need to find his boss and let him know that the guy needs trained properly. There are very few emmisions things installed on a 69 car, and even less on a 69 p/u.
Old 08-05-2003, 04:40 PM   #8
bpmcgee
bpmcgee's Avatar
In Illinois, if you're in an emissions area, you DO have to pass emissions for this truck. Although they haven't opened my hood, you should have just a PCV.
Also, for that year, you'll just have to pass an idle test, nothing more.
At 1300 PPM, I'm guessing you can actually smell the truck running rich. This should be pretty easy to fix.
High Hydrocarbons means you're running rich. If you've rebuilt or replaced the carb, definitely get out a vacuum guage and set the idle mixture screws. Also, the things you've suggested all work. I've been told that changing the oil also helps.
If nothing else helps, check for a vacuum leak. These can lead to really poor mixture.
If you have more questions about Illinois emissions, let me know. I've had to fight this recently.
Good luck,
Brian
bpmcgee is offline   Reply With Quote
Old 08-06-2003, 02:08 AM   #9
JREs69er
Thanks fellas, appreciate all the info. I'll let you guys know how things work out.
