Old 07-14-2014, 12:14 PM   #1
Sklptrljay
Sklptrljay's Avatar
Axle swap compatibility?
I found a rear end that is from a 72 Blazer. It's a 6 lug. Will 5 lug axles from a 71-72 fit in this rear end?
1971 C/10 SWB, 15x8 Rallys, 4.5" X 7" static drop, C-notched, 350/350, 3.73 Posi. .........A 383 and Gear Vendors are on my bucket list.
1972 GMC 4X4 K1500 Survivor - Sold
No matter what problems life throws at you, your time on Earth can be incredibly fulfilling and rewarding.....if you just lower your expectations. -Phil Dunphy
Sklptrljay is offline   Reply With Quote
Old 07-15-2014, 11:13 AM   #2
Sklptrljay
Sklptrljay's Avatar
Re: Axle swap compatibility?
Bump.
Anybody know?
Old 07-15-2014, 04:44 PM   #3
fp1967
fp1967's Avatar
Yes, they will fit.
fp1967 is offline   Reply With Quote
Old 07-15-2014, 10:40 PM   #4
Sklptrljay
Sklptrljay's Avatar
Thanks fp1967. Is something you have done before? Is it simply a straight swap or are there any modifications to be made?
Old 07-16-2014, 08:37 AM   #5
Steve Cole
Were Blazers running 6 lugs in 72? I know the trucks were not. You should measure your rear end to be sure it's not an earlier, more narrow one. Swapping axles in trucks is an easy process, just take your time and don't disturb the spider gears. Do a search here, there is a good write-up on doing this.
Steve Cole is offline   Reply With Quote
Old 07-16-2014, 09:15 AM   #6
imjeff
imjeff's Avatar
K trucks were 6 lug in 72.
I know a guy who's addicted to brake fluid. He says he can stop any time.
72 K10 396
75 Cj5 MPI 350 Chev
67 Chevelle 396, 4 speed
74 FXE
08 Tahoe
imjeff is offline   Reply With Quote
Old 07-16-2014, 06:50 PM   #7
Sklptrljay
Sklptrljay's Avatar
Here are some pictures the guy sent me about this rear end. He is 2 hours away so I haven't seen it myself. He snapped these before he went to work so it's all I have right now.
I would like to see a pic with the carrier rotated about 90 degrees because I don't see any clutches, so It looks like an open. But...I've never seen gear markings on the carrier like this. It is 3.73, and supposed to be from a 4WD. Can anyone identify this style?
Old 07-16-2014, 07:32 PM   #8
imjeff
imjeff's Avatar
Wow! Those ring gear teeth look hammered and that carriage looks like it was attacked by a ring gear! I don't know if it's worth four hours of drive time, let alone cash. Looks like you would need to replace everything in the case and, by the looks of the carriage, maybe the housing as well. Please follow up if he tells you what happened to it.
72 K10 396
75 Cj5 MPI 350 Chev
74 FXE
08 Tahoe
Old 07-16-2014, 07:44 PM   #9
Oldtruckfanatic
Truck junkie
Oldtruckfanatic's Avatar
Looks like it lost a pinion bearing or the nut backed off. I wouldnt buy that. It would cost less to buy a better rear end than rebuild that one.
Oldtruckfanatic is offline   Reply With Quote
Old 07-16-2014, 10:35 PM   #10
Sklptrljay
Sklptrljay's Avatar
Shows how smart I am. I was looking at it on my phone and I was thinking it was some different kind of carrier. Now that I looked at it close up on a computer screen I can see it's all gnarled.
Well, back to the drawing board. I'll find one eventually.
