Old 08-04-2014, 07:15 PM   #1
miniman
Brake lines
Anybody have any suggestion on where to get some pre-bent stainless brake lines other that Inline Tubing? I ordered inline tubing and they are horrible. Nothing fits correctly, and I called them to tell them they messed up on my order. They said they were the correct ones. Absolutely horrible. Thanks for your help.
miniman is offline   Reply With Quote
Old 08-04-2014, 07:53 PM   #2
JonnyC10
Re: Brake lines
CPP sells them. classicperform.com
JonnyC10 is offline   Reply With Quote
Old 08-04-2014, 08:06 PM   #3
amashal
amashal's Avatar
Re: Brake lines
I bought mine from Classic Industries. First set was wrong due to misprint on their website. Talked to tech department before getting another set sent to me and they were very helpful making sure I got the correct lines. He was able to give me fitting to fitting lengths. I got the second set and they fit perfect.
amashal is offline   Reply With Quote
Old 08-04-2014, 08:07 PM   #4
Vintage Windmills
Vintage 4x4s
Vintage Windmills's Avatar
Re: Brake lines
The Right Stuff fit pretty well, not perfect but not too bad.
67 GMC K1500 Custom- 305V6 SM420, PTO, Ram Assist, yellow (the outcast) (project period correct upgrades)
67 GMC C2500 351V6 TH400, AC, PS, PB (can't decide what to do with. Update, decided to keep and will restore )
86 CHV K30 502 th400, apple red NEW
71 CHV K20 350 SM465, ochre (saved work truck)
71 CHV K20 292 SM465, white, tach, PTO, (future project)
72 CHV K20 350 350th, medium blue (project stocker)
01 CHV K2500hd crew, indigo blue
^3 dont run and the others don't see winter either
'86 K30 Cummins "Fireside" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=649649
'71 K20 "get driveable" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=590642
'72 K20 Build Thread: http://67-72chevytrucks.com/vboard/s...=493477&page=6
Vintage Windmills is offline   Reply With Quote
Old 08-04-2014, 08:46 PM   #5
FlameOut
Re: Brake lines
I bought mine from Right Stuff also. For my 72 K10 and my 67 ChevelleSS. Nice fit. Not 100% perfect, but I was happy with the fit
2004 Chevy Silverado Z71 Ext Cab 1500
1972 Chevy K-10 SOLD
1967 Chevelle SS
FlameOut is offline   Reply With Quote
Old 08-04-2014, 09:04 PM   #6
ItsRandy
ItsRandy's Avatar
Re: Brake lines
I had the same experience you had. I bought some straight lengths of stainless tube for fuel line, trans cooler lines, oil cooler lines, a couple of good tubing benders and bent the lines myself. I wish I would have thrown the brake lines away I bought and bent those myself also. It's not that hard but takes a little time and it's well worth it.
ItsRandy is offline   Reply With Quote
Old 08-05-2014, 12:32 AM   #7
FirstOwner69
FirstOwner69's Avatar
Re: Brake lines
I got mine from The Right Stuff (www.getdiscbrakes.com) in 1999. They did require some tweaking, and a couple were wrong when I finally installed them in 2012. I called them, and they bent (no pun intended) over backwards to make it right. They even bent a couple to match my originals... at NO ADDITIONAL CHARGE after 13 years. Can't beat that for customer service!
FirstOwner69 is offline   Reply With Quote
Old 08-05-2014, 06:21 PM   #8
miniman
Re: Brake lines
Sounds good, thanks for all the help.
Old 08-06-2014, 01:11 AM   #9
John H.
John H.'s Avatar
Re: Brake lines
The Right Stuff Detailing. I have known the owner for over 30 years. These trucks are confusing to all the tube suppliers. If they are wrong or don't have your specification, they will bend it for you. They have the CNC laser wand to scan the line into their machine. Pretty cool process.
John H. is offline   Reply With Quote
Old 08-05-2014, 08:47 AM   #10
Tom Vogel
2WD Jimmy
Tom Vogel's Avatar
Re: Brake lines
That IS strange. Mine were perfect. hmm
Tom Vogel is offline   Reply With Quote
Old 08-05-2014, 12:29 PM   #11
cdowns
cdowns's Avatar
Re: Brake lines
i've never had a problem with inline tube stuff
might help if you said what you were trying to order some info helps to determine the problem if it is them or you just dont know how to order the right stuff
Old 08-07-2014, 07:06 PM   #12
davepl
davepl's Avatar
Re: Brake lines
Meow. No wonder your avatar is a cat :-)
1970 GMC Sierra Grande Custom Camper - Built, not Bought
1969 Pontiac 2+2 427/390 4-speed Coupe
1969 Pontiac 2+2 427/390 4-speed Convertible
davepl is offline   Reply With Quote
Old 08-08-2014, 12:55 AM   #13
oldschool18
oldschool18's Avatar
Re: Brake lines
I have know idea what the ratings on the tubing are I just get the work order and run it, but I think the wall is .017 but im not sure but I can find out. The brake lines and gas lines are made out of large coils, my side of the plant runs straight lengths. I just get to run them in the furnace to anneal them.......Now I will try and explain this without sounding stupid....We get copper and brass products in as coils or in straight length, now the coils aren't small they are 54" or 84" and come in all different OD and wall thicknesses. Like the Moroso alum tubing starts out as .753 x .049 and then it gets drawn down to about .670 x .042 and then drawn again down to the finish at .500 x .035.....now that's for 1/2 inch line there are many others.....3/8....1/4 and so on. The copper you buy in most hardware stores for water isn't crap its just made for inside water line..........it all depends on the alloy the size, hardness and how it is used......well first pic is of finished coils coming out of the furnace...second one is of 54" aluminum 303 alloy coils and the third is of the machine that makes them in to 18" coils, the guy was working on setting it up or I was going to take some video of how the machine works.
_________________________________
62 Impala
70 C-10 LWB
71 K-10 SWB
85 C-10 LWB==SOLD
01 2500 HD
Members Met......2003Silverado (Dave)
oldschool18 is offline   Reply With Quote
Old 08-05-2014, 05:10 PM   #14
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
Re: Brake lines
Mine too... couldn't be happier with my SS Inline Tube lines.
Gary
'cuz chicks dig scars...
I would never rebuild a 305.
Old 08-05-2014, 12:34 PM   #15
mikewoods
mikewoods's Avatar
Re: Brake lines
I know for a fact that most, if not all of the vendors mentioned in this thread get their pre-bent lines directly from Inline Tube.
"The Mustang’s front end is problematic, get yourself a Firebird. "- Red Forman
mikewoods is offline   Reply With Quote
Old 08-05-2014, 05:22 PM   #16
davepl
davepl's Avatar
Re: Brake lines
This: http://inline-tube.pissedconsumer.com/
If it's a half-ton small block, you'll be fine. But if it deviates in any way (3/4 ton, big block, special paint code) then no one makes anything for it and you'll have to make your own.
If you're ever doing to do it on more than one car, I'd buy the hydraulic flaring tool (Mastercool, Mac, a bunch of people rebrand the same one, but its a great one), tube nuts, and tubing, and do it yourself.
It's either quite fun and rewarding or really frustrating, but it's a good skill to have. Your first time out is easier with mild steel, because stainless is hard to bend. But it was my first time and I went stainless.
Old 08-06-2014, 01:10 AM   #17
oldschool18
Re: Brake lines
get yourself a roll of copper nickel annealed tubing, it bends really easy and most bends you don't even need a tool. Its lasts forever..........
62 Impala
70 C-10 LWB
71 K-10 SWB
85 C-10 LWB==SOLD
01 2500 HD
Old 08-06-2014, 10:35 AM   #18
LockDoc
The Older Generation
LockDoc's Avatar
Re: Brake lines
Originally Posted by oldschool18 View Post
get yourself a roll of copper nickel annealed tubing, it bends really easy and most bends you don't even need a tool. It lasts forever..........
I agree with oldschool. I used the newer NICOPP brake lines (nickel+Copper+Iron) on one of my projects. Really easy to bend and they will not rust. CNC 325 is 3/16" and CNC 425 is 1/4". I bought mine from this guy:
http://www.ebay.com/sch/swalsh72/m.h...p2047675.l2562
Best price I could find at the time. You can actually coil it around a 1" wooden dowel by hand without kinking it. It also flares easy with a regular double flaring tool and there are coated flare nuts available. Some of the auto parts stores carry it but it is quite a bit more $.
LockDoc
Leon
Old 08-06-2014, 12:48 PM   #19
Classic Heartbeat
Project Junkie! Fishing Poor!!
Classic Heartbeat's Avatar
Re: Brake lines
I have been an In-Line Tube dealer for many years and I must say that most of the time they get it right, however if they get it wrong it is their opinion that it is never their fault!! I agree their customer service is crap even for their long time dealers. It is incomprehensible to them that they may have made something wrong.
They will make you send lots of pictures, (for what reason I don't know) because in the end you will have to send them your originals so they can copy them! Then you get "Custom bent" lines. (and they get a correct sample to copy) They say your truck is different than every other truck out there... We talked to our technicians and they say the lines sent were correct. Not just lines mind you, but e-brake cables too. I could go on and on, but for the sake of this thread I wont.
Just know that if you buy their products you may be in for a fight and added expenses if they are wrong. I think that all the picture taking is designed to frustrate you into just making what you have work!! WES
On-line catolog
Classic Heartbeat Pickup Parts
WEHEPP@comcast.net
Call us Toll Free (888) 338-2502
Like Us on Facebook
No appointment necessary.
72 BB Chevy Custom Deluxe / Custom Camper
67 I-6 (Soon to be 5.7 LS1) Panel
68 BB Chevy Short Bed
72 6.0 LQ9 Short Bed Chevy 4X4
Olympia's fastest growing truck parts supplier.
Olympia's home for Wayward Chevys
Classic Heartbeat is offline   Reply With Quote
Old 08-07-2014, 10:23 AM   #20
Fitz
Re: Brake lines
Originally Posted by Classic Heartbeat View Post
I have been an In-Line Tube dealer for many years and I must say that most of the time they get it right, however if they get it wrong it is their opinion that it is never their fault!! They will make you send lots of pictures, (for what reason I don't know) because in the end you will have to send them your originals so they can copy them!
In line Tube uses a CNC bender. They compare the photo's to their CAD file rendering to look for errors. If you do send originals that aren't too bent up they use a reference table and prototyping arm to form a 3D plot of the tubes you sent for comparison to that same file. That is the same process they use to make a prototype set of tubes not currently a part of their catalog.
They usually do get the bends correct but when they are bad they are very very bad. They just can not believe their magic machine can make a mistake but the fact is, the tech running the machine probably called up the wrong file.
Fitz is offline   Reply With Quote
Old 08-06-2014, 01:06 PM   #21
CUSTOM/10
CUSTOM/10's Avatar
Re: Brake lines
LockDoc
Now you tell us about the NICOPP brake line, right after I finished bending all my own lines in Stainless Steel..... Geeeez..... "LOL"
The SS is tough to bend and flare & is unforgiving if you make a mistake !
Sounds like the NICOPP is nice stuff to work with.
Gary
Gary
72 SWB 4x4
My 72 SWB Build
http://67-72chevytrucks.com/vboard/s...d.php?t=259859
CUSTOM/10 is online now   Reply With Quote
Old 08-06-2014, 02:24 PM   #22
LockDoc
LockDoc's Avatar
Re: Brake lines
Gary
Yeah, I just watched your build and waited until you finished your lines to post about it....... As tough as the regular lines can be I can't imagine the stainless ones. If a guy is using stainless because of rust issues the NICOPP would be the best of both worlds, won't rust and easy to bend.
LockDoc
Leon
Old 08-06-2014, 06:09 PM   #23
CUSTOM/10
CUSTOM/10's Avatar
Re: Brake lines
LockDoc
I knew it !!!! "LOL"
I believe stainless is steel with nickel, so the copper must help with making it a bit softer and easier to work with. I used SS for it's looks and it's corrosion resistance. Next time around ( If there is one ) I'll use SS fittings & the NICOPP tubing ! But at this point I doubt there will be a next time .... I'm most likely going to enjoy the one I'm doing now for as long as I can !
Gary
Gary
72 SWB 4x4
My 72 SWB Build
Old 08-06-2014, 10:24 AM   #24
my67c20
Re: Brake lines
Make you own. Did the same thing bought from In-line, did not fit, tried Right Stuff, did not fit. I just took there parts re-bent them, added what was needed, and called it a day.
my67c20 is offline   Reply With Quote
Old 08-06-2014, 01:21 PM   #25
my67c20
Re: Brake lines
Don't get me wrong, the price was right, the parts looked good, the delivery was prompt from both vendors, but they did not fit as i was expecting. Probably has something to do with disk brakes on a 67. I did not call customer service because i weighed out the cost vs the benefit, and i was ready to do the work, and just did not want to wait. I did use 90% of the material, just refit / re-flared, as i required. There has been plenty of posts about how good these products fit there rigs, so if this is the route you choose, then rock on. For me in the i learned doing the lines, so next projects its all me. Just my 2 cents. Oh and don't be cheap on a bender or flaring tool.
