Old 09-13-2014, 09:34 AM   #1
1968c15
american autowire 68 stepside questions
So I am in the process of installing my american autowire harness part #510333 on my 68' c15. I am confused on the rear body harness when it says on stepside models you must build the entire rear extension harness as you will NOT be using the rear pig tail assemblies. There is no diagram for the stepside models so Im pretty lost. heres a link to the instructions. http://www.americanautowire.com/PDFL...20IN%201.0.pdf
I have more questions but would like to get the rear knocked out now thanks
1968c15 is offline   Reply With Quote
Old 09-13-2014, 09:51 AM   #2
1968c15
Re: american autowire 68 stepside questions
ive got the stepside extensions but instructions arent clear how to hook them up to the sockets part E
Old 09-13-2014, 11:26 AM   #3
1968c15
Ok got the rear harness in. The po installed some weird taillights and diddnt realize until digging around on the web. Just front lights and engine to go!
Old 09-13-2014, 01:12 PM   #4
michael bustamante
michael bustamante's Avatar
Youll have to post pics so we can see how it looks in the engine bay and under dash
1967custom
michael bustamante is offline   Reply With Quote
Old 09-13-2014, 01:15 PM   #5
1968c15
definatly will.. still got a few loose wires under dash im not too sure too sure about but should have the engine bay knocked out tonight.
Old 09-13-2014, 01:58 PM   #6
1968c15
probably a dumb question but if im using mechanical oil press. and water temp gauges can i leave the sending unit wires for both disconnected?
Old 09-13-2014, 02:00 PM   #7
1968c15
atleast till i go electric?
1968 gmc c15 stepside
screw p/o's
Old 09-13-2014, 04:14 PM   #8
jmorri34
jmorri34's Avatar
Yes if you are using mechanical the electric wires dont need to be run but either way make sure you have some kind of gauge working so youll know whats going on with the engine.
1969 cst prostreet
http://67-72chevytrucks.com/vboard/s...d.php?t=568661
jmorri34 is offline   Reply With Quote
Old 09-13-2014, 05:30 PM   #9
1968c15
Thanks. Another question. I also run an aftermarket tach. Should I splice that into the tach wire on the distributer along with the coil/tach wire from the new harness or is the wire on the harness not needed since I don't have a factory tach?
screw p/o's
Old 09-14-2014, 12:56 PM   #10
jmorri34
jmorri34's Avatar
Hard to remember, My harness for a 69 came with a tach wire and I think I used the harness wire that also plugged into the distributor. You will have to look at yours and make sure it is the same. If there is a Tach wire in the harness that is already plugged into the tach plug on the distributor just use that for a nice clean look. I hope this helped
1969 cst prostreet
Old 09-14-2014, 09:29 PM   #11
ujsf01
ujsf01's Avatar
I just finished installing this kit on my 67 stepper and I also install these professionally through a small part-time business I own specializing in electrical work. I would simply connect the tach wire in your new harness to the signal wire on your tach, splice the tach illumination wire into any of the grey illumination wiring in your new harness to light it up at night, then you simply need an ignition hot connection for power and, of course, the ground. IMO, American Autowire is the best bet going dollar for dollar. I also installed a Dakota Digital VHX system and it was so simple to connect to the AA harness!
Steve McMillen
ASE and GM certified Master Technician
25 years+ experience
No, I do not know it all, that's why I attend tons of training.
ujsf01 is offline   Reply With Quote
Old 09-17-2014, 07:54 AM   #12
jmorri34
jmorri34's Avatar
1969 cst prostreet
