Steering Column Mount to Dash??
I need help AGAIN! I've started trying to re-install my steering column. No problem with the firewall mount but I've gone totally brain-dead on the dash. I have the two metal brackets that bolt up to the bottom of the dash, one underneath and the one where the instrument panel is - but even after tightening these the column is sitting loosely at least 1/4" to 1/2" below the rounded fitting in the dash. Of course, I didn't take pics when I pulled it out
![]() Thanks, David
David Next project - 1953 Chevy 150 2 Dr Sedan. https://www.chevytalk.org/fusionbb/s...hp?tid/355913/ |
![]() Join Date: Jun 2014
Re: Steering Column Mount to Dash??
Do you have the black rubber donut piece that goes around the column and fills the gap between the column and where it touches the cutout in the bottom of the gauge cluster bezel?
1972 Chevrolet C20 Cheyenne Custom Camper LWB - 350 / 330 HP GM Crate - TH350 / Mild Shift Kit - Dark Blue / Medium Blue - Paint Code 559 |
![]() Join Date: Apr 2010
Take a picture and show us what you have
Here are some pics of what I have. I took everything apart about 5 years ago and THOUGHT that I had bagged/tagged everything. Apparently, my organizational skills are on par with my powers of recollection. Apologies for the pics being oriented wrong.
There is a U shaped bracket that is above the large square bracket that has the rubber stop pad for your brake pedal. That is the bracket that holds it tight, is that bracket there?
Old member
You have to take the brake stop plate back off and the black trim piece. Look under the dash above the square brake plate. A u shaped bracket goes around the column and bolts into the under side of the dash.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
All about them K’s
Where does the black piece go? I bought my truck with the column hardware missing and I've acquired the plate and u strap but have not seen the black plate till now. If someone could post a pic of it all together that would be awesome!
Tyler '57 3100 http://67-72chevytrucks.com/vboard/s...d.php?t=813888 '72 K20 Cheyenne http://67-72chevytrucks.com/vboard/s...d.php?t=662879 ‘69 K10 SWB http://67-72chevytrucks.com/vboard/s...d.php?t=805206 '98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 315/75/16's ‘87 IROC-Z all original 50K mile survivor TPI 305 IROC Blue ‘10 Camaro 2SS/RS Aqua Blue Metallic #93 -version 2.0 ![]() |
#8 | |
The Older Generation
I don't have a pic but after all the other pieces are bolted on this goes under the dash and the "U" shaped part fits up around the rubber collar at the instrument panel.... LockDoc
All about them K’s
Ok. Thanks for that. Putting together what someone else took Part with all pieces missing can be challenging. If any one has a pic that would be great.
![]() Join Date: Jan 2008
This site is amazing! The exact thing happened to me and I found this thread with a search for 'steering column mount'. Great information even though it was 2 years ago.
![]() 69 K10 SWB Project Dream '69 2011 K2500 Silverado Beat to fit, Paint to match Dream '69 Build Thread |
I feel your pain! Try putting together a complete "Basket Case" I literally, had to put every single piece of this truck back together, and what was missing or damaged (not very much) I searched for good used parts where I could find them, or settled for some small repro parts.
I'm hoping to fire it up tomorrow for the first time! I still have to install the bulk of the exterior trim, and the door windows/door panels, but, I have my priorities! Have a good one! Ben Smith ![]() |
I ask the same question about 2 months ago. My truck was completely disassembled when I bought it. PO just threw everything in boxes, nothing labeled or marked in any way. This gang sure helped me start to get mine back together.
Sorry for reviving old thread......Are these brackets year specific or are they same across the board for 67-72. Also, are they the same for auto vs 3 speed on column? I have a 68 3 speed on column and I have located some brackets off of a 71 auto. Will they work?
#14 | |
LockDoc.
Leon Locksmith, Specializing In Antique Trucks, Automobiles, & Motorcycles (My Dually Pickup Project Thread) http://67-72chevytrucks.com/vboard/s...d.php?t=829820 - Last edited by LockDoc; 12-04-2017 at 12:25 PM. |
#15 |
Ok. Great. Thank you for your help!
#16 |
#17 |
http://67-72chevytrucks.com/vboard/s...unts+installed these are all the pieces you need
