Old 08-14-2003, 04:41 PM   #1
bucket
bucket's Avatar
Angry new engine frustration continues
ok......if you remember i was leaking coolant. i resealed each head bolt one at a time and i think the coolant leak has stopped. i still have the oil leak. not valve covers....replaced those and they are dry. not intake.....removed and resealed w/ black rtv. the oil is collecting on the sides around whee the block meets the bell housing midway down (around starter on one side and clutch linkage on other. seems to make it's way down to the belly of transmission. oil pan is dry. the only thing i can think of is rear cam plug. oil seems to high up on block to be rear main.
this is really driving me nuts. my wife even more so since it is beginning to cut into time w/ her and our 5 month old. i just need to finish it up!
ideas?????
bucket is offline   Reply With Quote
Old 08-14-2003, 07:47 PM   #2
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
Do you have a copper line to the oil guage or teflon. May want to check the line and brass fittting that screw's into the block. Just a suggestion not sure it will help ya or not.
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
FRENCHBLUE72 is offline   Reply With Quote
Old 08-14-2003, 07:55 PM   #3
gmc67swb
gmc67swb's Avatar
ARE YOU POSITIVE IT'S NOT THE INTAKE. I HAD A SIMILAR PROBLEM ONCE. I USED THE RTV ON ON THE ENDS OF THE INTAKE AND DIDN'T GET THE BEAD THICK ENOUGH.
GM 330HP/350, Magnuson 122HH, Tremec TKO 5spd
gmc67swb is offline   Reply With Quote
Old 08-14-2003, 08:08 PM   #4
Gordo
If you can eyeball the front surface of the flywheel (engine side) and it looks like oil has been spinning off of it, it's probably the rear main, if it's dry it's not the rear main.
1971 C10 swb stepside 350/700R4/3.73posi (retired as of 4/22/03)
1998 S10 short bed
2002 S10 Blazer
1942 Oldsmobile
1958 Massey Harris Pony
1951 Wife
Killingworth, Connecticut
May those who love us, love us, any of those who do not love us, may God turn their hearts.
And if God is unable to turn their hearts, may he turn their ankles so we may know them by their limping.
A man who works with his hands is a laborer; a man who works with his hands and his brain is a craftsman; but a man who works with his hands and his brain and his heart is an artist.
Gordo is offline   Reply With Quote
Old 08-17-2003, 05:18 PM   #5
bucket
bucket's Avatar
took the flywheel cover off and the whole inside of the bellhousing is wet. but.........strange thing is the engine side of flywheel is dry, end of crank seems to be dry, hard to see but the cam plug seems to be dry. basically, the engine side of the flywheel is dry, tranny side is wet, dripping of clutch fork, etc. has anyone heard of a input shaft seal leaking SO bad on a four speed that it flings it around? if so, is it easy to fix?
Old 08-17-2003, 05:32 PM   #6
nu2-72
You are running a manual transmission? Did you put the pilot bushing back in the crank after the rebuild?
72 3/4 4x4 350 4spd
72 3/4 4x4 350 auto
2004 Duramax Silverado 4x4
2006 Duramax Crew cab 4x4
2010 Harley Ultra Limited
2011 Harley Street Glide
nu2-72 is offline   Reply With Quote
Old 08-17-2003, 05:36 PM   #7
bucket
bucket's Avatar
Pilot bushing is there....in fact I never removed it. it looked fine when compared to a new one.
Old 08-18-2003, 01:01 PM   #8
bucket
bucket's Avatar
anyone????????
Old 08-18-2003, 01:23 PM   #9
jhow66
jhow66's Avatar
Sounds like you have a bad bearing on input shaft that moves so much tjst seal cannot handle it. You should be able to tell if it is trans oil or engine oil by feel or smell . Trans oil will have a much more heavy odor.
56 Chevy Bel-Air 2dr. HT (purchased new)
71 Chevy Cheyenne SWB PU (502HO)
65 GMC short bed step--work in progress and my gofer
jhow66 is offline   Reply With Quote
