Mike! Window motor question.
I'm replacing the passenger side motor and I was a bit confused reading yours and midnight's write-up. For the passenger side, is the below pic the correct way to put the regulator in the vise?
Robert Current: 1986 SWB Silverado 4.3 / TH400 Past: 1985 SWB Silverado 305 / TH350 - sold 1995 1987 1/2 ton Silverado - FI 350 / 700R4 sold 2007 |
You get what you pay for
![]() Join Date: Dec 1999
Yes.
Sorry about the confusion. ![]() I need to rework the article some to make it more clear.
Mike 1985 Chevy C-10 |
Crap! I got the motor changed out with no hassles. But, when I tried to get the damn thing back in, I couldn't get the alignment bolts back through. After 30 mins. of wrestling and cutting my arm up, I thought maybe the window wasn't all the way up. I'm pissed off at this point and decided to try and jogged the window up alittle.
![]() ![]() sorry, had to vent, and my wife isn't here.... :evil:
Hey guys,
I found a way to cheat on the window motor thing. I popped off two of the three round plastic guides that are on the end of the regulator. They are a little tough to get off but they eventually did. I took off the one that was attached to the regulator arm that slides into the channel on the door and then one on one of the window arms. I then just slid the plastic guides into the tracks. Then I used a pair of channel locks to snap the plastic guides back into place. It was fast and a swore a lot less! I wondered if anyone else has done it this way? Mike H |
Would running the motor unbolted to the door burn it up? Need some suggestions on how to get the bolt lined back up. Please excuse my craptastic pic.
You will need to move the regulator. It looks like it slipped on you. No, it won't hurt to run the motor if it's not bolted in. Just don't get you fingers in the gear.
![]() From your drawing, it won't take much get it in the hole.
