Old 12-18-2014, 10:08 PM   #1
kevinr1970
What year did D60's start in K30's?
Or maybe a better question is what front end should be under a stock '76 K30?
The locking hubs look different than what I have seen before, almost pyramid, or conical shaped.
I haven't been able to look under it yet, just briefly from the side. Any advice on identifying what it is? I tried to google an image for the differences like for a rear, but haven't found anything for fronts.
2009 Honda Fit CfC (bsf 44.9 mpg)
2000 Tahoe Limited
1991 GMC CrewCab Dually 2wd, will end up swb, not dually and replace CCswb below
1991 GMC CrewCab Dually 4x4, just going to fix things up for now
1982/1989 K5/GMC Jimmy 2wd
1987 GMC 1/2 ton swb 2wd Crew (sold)
kevinr1970 is offline   Reply With Quote
Old 12-18-2014, 10:37 PM   #2
streetrodchev
streetrodchev's Avatar
Re: What year did D60's start in K30's?
1977 is the first year GM put a Dana 60 in the front of the trucks. They didn't make a K30 before that.
If it is the original axle in a '76, then it should be a Dana 44.
'46 GMC---355,TH400, 9"
'66 K20---350, SM420, T221, D44, HO72, 4.56
'87 K30---tbi 350, TH400, NP205 twinstick, D60 powerlok, 14ff Detroit, 4.10
streetrodchev is offline   Reply With Quote
Old 12-19-2014, 06:58 AM   #3
andrewmp6
The diff covers are the same no matter if its front or rear.Other ways to tell http://www.pirate4x4.com/forum/newbi...a-44-60-a.html
Old 12-19-2014, 09:12 PM   #4
kevinr1970
The ad says '76 and these are the pictures he posted?
Doesn't mean something hasn't been swapped over time I suppose...
2000 Tahoe Limited
Old 12-20-2014, 12:04 AM   #5
streetrodchev
That is not the original axle. In '76 GM used internal lockouts. The picture is an external lockout. Looking at the front of the axle, there is a number cast in to the lower right rib of the center section. Post a picture of the steering knuckle.
Old 12-20-2014, 03:00 AM   #6
mr.chevyblack
mr.chevyblack's Avatar
in 76 they had big hub 44 witch has external mount hubs same axel as a 3/4ton but the 1 ton tons had the big 8" frame channel in the 1 ton crewcabs 77 was the first year for a dana 60
mr.chevyblack is offline   Reply With Quote
