02-07-2015, 03:47 PM | #1 |
Front coil spring side up
Hi, I just installed 2" lowering springs on my 69 c10, after lowering, the right side is a good inch higher. I thought maybe I put the spring in upsdue down since the Belltech lettering on the spring was upside down. So I just flipped and put it down again and still an inch taller
Looking at the spring it looks like one end is a bit smaller (tighter coil) than then the other. Mt question is: Which end goes up top, and should the spring have different ends? Yes the springs in the lower notch just fine, confused. Any ideas would be appreciated. Thanks, clay |
02-13-2015, 09:10 PM | #2 |
Re: Front coil spring side up
Pigtail goes up, and there's a metal flange/cup in the upper spring mount that the spring wraps around. Look up inside your crossmember and you'll see what I mean...
Travis' Tribute Truck - 65 C10 Frame Up Restoration http://67-72chevytrucks.com/vboard/s...d.php?t=495073 |
