454 v8
Is this much of a common swap? i've been looking into it and having issues finding much information on it, it seems cutting into the firewall is a minimum requirement, and very likely some shaving off of the frame, if anybody knows of a good resource for this swap, or has done it themselves, any information would be greatly appreciated.
2004 Sierra 2500HD - New DD / Work truck 2006 Suzuki GS500 - rebuilt after wreck (summer DD) ![]() 1966 Chevy C20 - Winter Project / Future work truck build http://6066gmcclub.com/forum/showthread.php?t=48548 2008 Lancer GTS - DD / Parts getter - Sold |
![]() Join Date: Mar 2011
Re: 454 v8
Start searching the build threads. There are a lot of big block swaps around here. One local guy that comes to mind is 66farmer. He's got a beautiful big block truck.
Sanity'66 http://67-72chevytrucks.com/vboard/s...d.php?t=515110 Long bed, Fleetside, Small back window I've Done So Much, With So Little, For So Long, That Now I Can Do Anything With Nothing. ![]() |
Re: 454 v8
the search is turning up with nothing for me, alot of 70's trucks, but ive not found any threads.
Re: 454 v8
Well try this thread; http://67-72chevytrucks.com/vboard/s...d.php?t=659330 by JonnyR...he is installing a 454 in his 65"
Projects: 65' Chevy C10 swb (rebuilt chassis) 65' Chevy Panel swb 64' Chevy C30 flatbed "above" 80' C30 "beneath") Parts: 66' GMC 2503 & 65' GMC I1500 |
Re: 454 v8
Thanks, I found a few this evening, but the info for each was completely different from the next so that makes it kind of rough to find the right info. Might have to go for a sbc swap, but I'd like a BBC project.
Re: 454 v8
What about the GMC 351E big block V6? I got one and they are HIGH TORQUE and get better mileage than a V8.
Re: 454 v8
I want a 60-66 4wd GMC with a 351M or a 305 big block V6, but I feel like the effort put forth into getting one and dropping it into a chevy C20 would outweigh the benefits, especially when cost wise I can get a SBC or BBC. I'd be all in if it was the original engine, and I am still strongly considering a 327 V8 as well. But the 454 idea popped up and I've been curious about it, some people said they got theirs to fit with no cutting at all, others claim you have to cut away a lot of the firewall.
Re: 454 v8
It's not that hard. Take a look at my build thread.
![]() ![]() Join Date: Apr 2012
Re: 454 v8
Theres a couple ways to do it. Im not a body man so I did not want to cut the firewall. I used stock 68-71 Chevy BB truck motor mounts. I did cut the frame back a little to get them to seat right. Rest is a bolt in with factory parts.Tall Valve covers just clear . I've done it twice now and its a blast to drive !
IS IT an EATON or Chevrolet rear axle https://67-72chevytrucks.com/vboard/...d.php?t=843778 The hubcap thread http://67-72chevytrucks.com/vboard/s...d.php?t=702839 WANTED : 1963-1966 6 Cylinder Fan Shroud WANTED :1964-1966 PANEL TRUCK |
Re: 454 v8
That looks awesome!! I am going back and forth between doing the big block or stroking my 350.
1966 Chevy C-10 350 Engine 700R4 |
![]() Join Date: Sep 2006
Re: 454 v8
Here is mine. We all do them differently. I opted for cutting the firewall only becasue I wanted my engine to sit back and I didn't have to redo the drive shaft. http://www.67-72chevytrucks.com/vboa...d.php?t=259536
"A man and his truck, what a beautiful thing" 65 Short Fleetside BBC 65 Long Fleetside 283 3 on the tree for now. my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536 |
#12 | |
Re: 454 v8
Will do when I find it. Search function seems to actually be working so I read a few more today.
Found it, hoorah for the search function. By the way I used to live really close to you, I'm from forest grove Oregon myself. Quote:
2004 Sierra 2500HD - New DD / Work truck 2006 Suzuki GS500 - rebuilt after wreck (summer DD) ![]() 1966 Chevy C20 - Winter Project / Future work truck build http://6066gmcclub.com/forum/showthread.php?t=48548 2008 Lancer GTS - DD / Parts getter - Sold Last edited by Hantke; 02-11-2015 at 03:23 PM. |
Re: 454 v8
Being that your trans mount is riveted to the frame , I think you will need to modify the firewall. I used an automatic and was able to slide the trans crossmember to where I needed it to be.
Re: 454 v8
Okay, I'm still debating if I want to cut into the firewall or not, it seems like a good way for me to mess something up. Maybe I should be looking for a SBC for this truck and wait for my 63 for the BBC swap. That's going to be the one I take extra time on to make everything perfect as it will be a daily driver build, the 66 is my tinker toy which is being built as a work truck.
Thank you for the great info though!
#15 |
Re: 454 v8
i use poly performance mounts, just have to cut a bit the chasis rails to make them fit properly. with tall valve cover and milodon oil pan clearance is ok anywhere.
Even if the engine is sitting a bit higher for me, i'd like it lower to get a better angle for my driveline. I drill new holes between the two available position on my chassis to get the engine as back as i want. When i replace the cab mounts and put the cab back square to the chassis all came pretty straight and i have a bit more room on the PS of the cab for the cab heater hoses through the firewall. didn't know what headers use anyway. |
