replacing cab
I have a 1982 k20 chev pu 4x4. I recently purchased a c10 cab, can anyone tell me what kind of problems I mite run into when replacing the cab other than the hump in the middle. The one on the k20 has bolts holding it down, so I was going to cut out the floor on the c10 and replace it with the bolt down section from the k20. I was told that this would work. Thanks for any help.
Re: replacing cab
What year is the c10 cab?
#3 | |
Re: replacing cab
Re: replacing cab
The c10 cab is a 1982 also.
Re: replacing cab
Other than the vin issue and hump your mint!!
Big Nate Carp. Local 224. Buy made in the USA! 03 F350 6.0 Daily Race Truck. 79 C70 366 Project Dump. |
Re: replacing cab
The c10 did not have ac, I was thinking I could cut that part of the firewall out on the k20 and weld it on the c10. Has anyone tried this. Thanks
Re: replacing cab
I have done that. I didn't weld it though, just a few sheet metal screws and seam sealer, The A/C box covered up the seam. I made a template of the A/C firewall and then made the Non A/C fire wall look like the other.
I have some pics in my 78 Big 10 thread |
Re: replacing cab
I wouldn't cut and weld just cut Out the c10. Less welding the better.
Re: replacing cab
So are you saying just cut the k20 and place it over the c10 area and cut what I need to open those areas and the other openings will be covered by this part?
Re: replacing cab
I welded in an a/c section of firewall on a non a/c truck. No problem if everything is removed for access.
