Frequent Flyer
Re: dumb question but...
Looks like the aluminum brackets on the 90-94 Chevy Truck Motors.
88-94 GM trucks (4.3, 5.0, 5.7L) & same years S10's w/the 4.3L v6.
It will also require all accessories as well and a reverse flow water pump... Ends up being $$$
#5 | |
You can purchase everything brand spankin new for $900 from Summit. While not 'budget', it's half of what Billet Specialties (Tru-Trac) or Vintage Air (Frontrunner) serp set-ups go for & comes w/new accessories. Or, you can snag the brackets from a used source & purchase a new alt, water pump, pwr steering pump, a/c comp, belt, & idler for approx $500. These set-ups are engineered to work for years/miles.
If you shop right you can snatch a whole motor, scrape the brackets and accessories you need off, and sell the bare motor for about what you paid for the whole thing.
Parts and more parts
If you get an engine out of a Camaro, the brackets are further apart at the top, to allow for the TPI intake to run through.
Frank |
