Proportionate valve or distribution valve
This may be a stupid question, but I don't know the answer and don't want to screw up a little thing. I am doing a front disc conversion on my 70 c10 and don't know if this valve will work with my disc brakes. Thanks
20' Daredevil (Ret)
![]() Join Date: May 2003
Re: Proportionate valve or distribution valve
Not a stupid question at all. That's a distribution block for drums/drums. When you convert to front discs, you'll want to change it out to a proportioning valve. I believe you should also change the MC but let's see what others have to say. MC for front discs uses a larger reservoir for the discs and a smaller reservoir for the rear drums.
If you want to get picky, the front discs, which operate at higher line pressure (the reason for the prop. valve) use 3/16" lines, and the rear drums retain 1/4" lines.
- Mike - 1972 K20 LWB 350/350/205 RIP El Jay |
#3 | |
Regards, Mike
I own 3 classic vehicles. 1971 LWB C10 Deluxe. 1974 VW Super Beetle. 1971 VW Fastback. The C10 and the Super Beetle run, the Fastback is just not there yet! Please visit my Super Beetle and Fastback profile on TheSamba. |
20' Daredevil (Ret)
Just going off my memory of working on my '72..... apologies if it's not quite accurate, but that's how I recalled it.
I finally got an email from Cpp, after 2 weeks, and that guy said that I had to change the master cylinder out as well. This is different than what the other guy told me over the phone. I checked the master cylinder that I have, and it does have a larger front cavity than the rear. I got in my proportion valve the other day. Should the master cylinder I have work?
Ok, thanks for the response. Next question, where is a good place to get one for my application?
Old member
Look at that steering shaft! Dang it man.
As far as the P/V order any ones for a disc to drum. You can get them at a good parts house to. When I did my rear disc swap I had CPP send me one with their kit. ![]()
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
I don't get it about the steering shaft. I took it loose to clean the steering box and the frame. Is there something wrong with it as well?
it should be more to the outside of the frame, in between the frame and left outer wheel house,and there is a small sheet metal brace that captures it if the rag joint fails.....but if you disconnected it, that explains it....
Ben ![]() |
Yes, I have it just sitting on the frame right now. I found this one on ebay. Would it work for my application? Thanks
http://www.ebay.com/itm/191444504548?redirect=mobile |
#11 | |
Old member
![]() Quote:
#12 | |
Old member
![]() Quote:
Next question. This valve has 2 inlets and 3 outlets, while my current valve only has 2 outlets. What do I do about that?I only have 2 sets of brake lines. One that goes to the back and on that T's off for both sides of the front brakes. Thanks
+1. When converting from drum/drum to disk/drum, you must replace the master cylinder and proportioning valve for units designed for disk/drum applications. The disk/drum proportioning valve also acts as a residual valve, so don't need to add those.
I did a drum/drum to disk/drum conversion (and added power as well) to my '52. You can see the proportioning valve that I mounted to the frame (on left of photo). ![]() |
#15 |
I figured out the extra outlet problem. Thanks
#16 |
>> both front and rear reservoirs are the same size<<
On drum brakes as the shoes wear down, the owner periodically readjusts the shoes or it may have automatic adjusters. The fluid level in the reservoir stays about the same when the shoes are new until they are worn out. Disc brakes have no adjustment for pad wear. As the pads wear from new, the fluid level slowly lowers and the volume of fluid behind the caliper piston slowly increases. The manufacturers use a larger volume reservoir for discs just in case the owner never checks the fluid levels. They don't want the brake reservoir to empty before the pads wear out and the screechers alert the driver. Most new cars have fluid level switches in the reservoir and idiot lights, because they know the drivers are too stupid to check the brake fluid on their own. >>The disk/drum proportioning valve also acts as a residual valve, so don't need to add those.<< Most Combination Valves, which include a proportioning sectionDo Not have residual valves built into them. Residual valves are very important on frame mounted Master Cylinders, because anytime the MC is below a wheel cylinder, gravity will push the fluid back into the MC and air will be drawn into the wheel cylinder or caliper . I hope you don't snag those low hanging brake lines.
'67 GMC 2500, 292, 4spd, AC |
#17 |
I called the cpp tech line yesterday to ask them about it. They said, that's I didn't have to change out the master cylinder. The one that's came with the booster I bought from them a few years back would work just fine. I did order the proportion valve off eBay and am waiting for it to come in now. On a side note, the cpp people charge $10 difference to get a booster with a proportion valve and one without, but charge $75 to buy one by itself with the bracket. I am not a mathmatologist, but that's doesn't add up to me.
#18 |
Now cpp is telling me that the drum/drum master cylinder is valved completely different than a disc/drum master cylinder. I don't know what to believe from them now. Dang it.
#19 |
I just pulled a mastercyl with booster from an 85 c10. used the lines from it and the proportioning valve, check out page 2 & 3 of the build thread in my signature. I used the entire front suspension and brake system from an 85, and then just got some couplers to hook the brake lines to the rear.
Built not bought! My dad always tried to convince me HEI was pointless! Welding is a lot like sex, you don't have to be great with the rod as long as you thoroughly prep the surface and your good at grinding ![]() My build : 68 C10 Short Bed Conversion |
#20 |
From my post above, the size of the reservoir has absolutely nothing to do with the operation of the brakes, Nothing. It only becomes an issue if you never check the fluid level.
#21 |
![]() Join Date: Apr 2012
I found this article helpful when I was setting up my brakes.
http://www.how-to-build-hotrods.com/brake-system.html
1971 C/10 SWB, 15x8 Rallys, 4.5" X 7" static drop, C-notched, 350/350, 3.73 Posi. .........A 383 and Gear Vendors are on my bucket list. 1972 GMC 4X4 K1500 Survivor - Sold No matter what problems life throws at you, your time on Earth can be incredibly fulfilling and rewarding.....if you just lower your expectations. -Phil Dunphy |
#22 |
That is because CPP is a joke. Shop elsewhere
1968 Chevy C10 307 3ott fleetside 1967 Chevy C/10 V8, 3spd, fleetside lwb.Sold 1967 Chev C/10 step, 383, M21. SOLD |
#23 |
I have 3 guys there telling me 2 different things. 2 say it is fine, 1 says no. Pretty upset at this point. You would think the tech people would be on the same page.
#24 |
Now the proportion valve I ordered doesn't fit my brake lines. The hits just keep on coming. Cpp still has conflicting tech support. Not sure what to do at this point.
#25 |
Honestly, I don't deal with CPP for reasons like that. Their tech support is inconsistent.
Lets try and assess what you have, and what you need. Why won't the lines fit? Are the lines too big, too small, wrong threads, not the right shape? What CPP master cylinder do you have mounted on your truck right now? Is it from a disc conversion kit? Drum/drum? Do you know the bore size in it? Do your best to be as informative as possible when describing the parts, model numbers, and issues you have with the parts- the more information we have, the easier it is to help get you on the right track. Best of luck. ![]() |
