![]() Join Date: Jan 2012
What driveshaft did you use?
I am not to this point yet, but the question has popped into my head.
Mine is going into a LWB 68. It will be a 5.3 with the 4L80 trans. Can I do a single driveshaft or does it have to be 2 piece? What driveshaft(s) did you use?
Matt Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=672655 "Father thank you for the gathering of friends, Father we give thanks for all the choices we've made because that's what makes us who we are, let us forever cherish the loved ones we've lost along the way and most of all THANK YOU FOR FAST CARS!" |
![]() Join Date: Jul 2014
Re: What driveshaft did you use?
I had Houston Drivetrain build a new shaft for my '86 swb. 58-ish inches, $355 OTD with new u-joints. Not sure how long it would be for a LWB, but they said anything over 72" needed to be aluminum(for a 1 piece shaft). For mine, aluminum would have been $200 more.
'83 Silverado Step Side '85 GMC short bed. '86 Chevy Step Side Custom Deluxe LQ9/4L80 swap (SOLD) |
The Older Generation
Yup, I think 72" is the max for a one piece shaft. I wouldn't go over that even with aluminum.... Just my 2¢ worth.... LockDoc
Is custom the only way to go with this or are there production driveshafts that will work also?
![]() Join Date: Sep 2005
I had my 2 piece cut down new ujoints and carrier bearing and had it balanced
Old member
When I had mine done they swapped it out for a 1 piece shaft.
I have a 71 LWB truck. ![]()
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
Andy, do you have leaf or coil springs?
Old member
Coils!
Not a very good picture but. ![]()
Did you have to modify the crossmember that the truck arms connect to? On my 68, that is where the carrier bering was housed.
I converted to SWB and did a one piece, but I had a drive shaft made from Tatton's Drive Shaft. If I remember, it was $220 shipped with no yoke. $280 shipped if I needed a yoke. He was great. I'd buy from him again.
