Old 09-26-2015, 07:33 PM   #1
ekgguy
ekgguy's Avatar
What driveshaft did you use?
I am not to this point yet, but the question has popped into my head.
Mine is going into a LWB 68. It will be a 5.3 with the 4L80 trans. Can I do a single driveshaft or does it have to be 2 piece?
What driveshaft(s) did you use?
Matt
Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=672655
"Father thank you for the gathering of friends, Father we give thanks for all the choices we've made because that's what makes us who we are, let us forever cherish the loved ones we've lost along the way and most of all THANK YOU FOR FAST CARS!"
ekgguy is offline   Reply With Quote
Old 09-26-2015, 08:40 PM   #2
Tilt
Re: What driveshaft did you use?
I had Houston Drivetrain build a new shaft for my '86 swb. 58-ish inches, $355 OTD with new u-joints. Not sure how long it would be for a LWB, but they said anything over 72" needed to be aluminum(for a 1 piece shaft). For mine, aluminum would have been $200 more.
'83 Silverado Step Side
'85 GMC short bed.
'86 Chevy Step Side Custom Deluxe
LQ9/4L80 swap (SOLD)
Tilt is offline   Reply With Quote
Old 09-26-2015, 09:38 PM   #3
LockDoc
The Older Generation
LockDoc's Avatar
Yup, I think 72" is the max for a one piece shaft. I wouldn't go over that even with aluminum....
Just my 2¢ worth....
LockDoc
Leon
Old 09-26-2015, 11:04 PM   #4
ekgguy
ekgguy's Avatar
Is custom the only way to go with this or are there production driveshafts that will work also?
Matt
Old 09-27-2015, 03:50 PM   #5
truckdude239
truckdude239's Avatar
I had my 2 piece cut down new ujoints and carrier bearing and had it balanced
David fuller
Ase Certified Mechanic
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
Old 09-27-2015, 04:23 PM   #6
Andy4639
Old member
Andy4639's Avatar
Thumbs up Re: What driveshaft did you use?
When I had mine done they swapped it out for a 1 piece shaft.
I have a 71 LWB truck.
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Old 09-27-2015, 11:13 PM   #7
ekgguy
ekgguy's Avatar
Andy, do you have leaf or coil springs?
Matt
Old 09-28-2015, 01:46 AM   #8
Andy4639
Old member
Andy4639's Avatar
Coils!
Not a very good picture but.
Old 09-28-2015, 08:58 AM   #9
ekgguy
ekgguy's Avatar
Coils!
Did you have to modify the crossmember that the truck arms connect to? On my 68, that is where the carrier bering was housed.
Matt
Old 09-28-2015, 10:36 AM   #10
Andy4639
Old member
Andy4639's Avatar
Nope they just took everything a part that the carrier attached to. Heres a couple more pictures. If I go any lower with it I'm sure I'll have to do some kind of moding to it though!
The rear end is up on jackstands so the shaft is higher when on the ground. I took thes while working on the rear disc brakes.
Old 09-28-2015, 01:22 PM   #11
ekgguy
ekgguy's Avatar
Thanks Andy, that helps a lot.
Matt
Old 09-28-2015, 02:39 PM   #12
bs46488
I converted to SWB and did a one piece, but I had a drive shaft made from Tatton's Drive Shaft. If I remember, it was $220 shipped with no yoke. $280 shipped if I needed a yoke. He was great. I'd buy from him again.
bs46488 is offline   Reply With Quote
Old 09-28-2015, 05:34 PM   #13
Andy4639
Old member
Andy4639's Avatar
No problem man. Anytime.
