Old 10-19-2015, 12:42 AM   #1
vancelot69
vancelot69's Avatar
Another axle question or two
Yesterday evening I noticed some petroleum on my inner tire. Is there a way to tell if it's the axle seal or brake wheel cylinder without taking it apart? If it turns out that it's the axle seal, am I correct thinking that I will have to remove the axle shaft to replace it, therefore I will have to take the C-clip out in the differential?
Thanks!
My toys:
1971 GMC Jimmy
2008 Hummer H3 Adventure
2003 HD Road King
vancelot69 is offline   Reply With Quote
Old 10-19-2015, 01:38 PM   #2
61K10
61K10's Avatar
Re: Another axle question or two
Yes. pull the tire and brake drum and have a look.
1961 chevy K10
my build is------------61K10 build
61K10 is offline   Reply With Quote
Old 10-19-2015, 08:57 PM   #3
kwmech
You could also inspect the master cyl reservoir to see if it's empty
Old 10-19-2015, 09:13 PM   #4
nonstop
Run your finger trough it and smell it. Both are distinct smells and texture.
nonstop is offline   Reply With Quote
Old 10-20-2015, 12:40 AM   #5
crazy longhorn
Fabricate till you "puke"
Just like I taught my sons...."run your fingers through it" then smell it I hope the mods have a little "humor" this nite? All jokes out, yes the gear lube does have a very "skunk" odor. the brake fluid , has a stinky /sweet smell. Longhorn
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
