Old 10-25-2015, 06:14 PM   #1
toolboxchev
Motor Oil
So I have an original style hyd flat tappet camshaft from Comp Cams and so far so good. It was my goal when I did a top end rebuild on this 100 k mile engine to get at least another 50 k out of it.
Comp Cams recommended their engine break in additive at every oil change pointing out to me that all motor oils do no longer have the Zinc and other additives that make a oil more friction reductive.
So far to date the only other thing I have found is the Valvoline VR-1 that has the same properties in a oil.
Well I have over 50 k now, and will be re-building most likely in the next year or so due to bottom end wear. I can still zhit and git without worry of losing something.
Who would know of other manufactures of quality stuff? Or what have you done to overcome today's crappy oils?
toolboxchev is offline   Reply With Quote
Old 10-25-2015, 06:17 PM   #2
hugger6933
Re: Motor Oil
If it has had decent maintenance I wouldn't worry much about it or the miles as long as it is performing OK
hugger6933 is offline   Reply With Quote
Old 10-25-2015, 06:27 PM   #3
Ruscal
Re: Motor Oil
Brad Penn sells the old green Kendall like oil that has performed well in the past. The additive package can harm modern cats, but most of us don't run one.
Russ
RC
Ruscal is offline   Reply With Quote
Old 10-25-2015, 08:33 PM   #4
sduckworth13
sduckworth13's Avatar
Re: Motor Oil
I've been using the Brad Penn 10W30 oil myself in a fresh rebuilt 350 sbc with a hydraulic flat tappet cam. I have 6500 miles on it. I haven't had a single problem.
Scott
sduckworth13 is offline   Reply With Quote
Old 10-25-2015, 11:30 PM   #5
twich3136
twich3136's Avatar
Re: Motor Oil
I use joe gibbs hot rod oil. no problems. my local napa carries it too which was a plus
USMC
SEMPER FI
68 Chevy Longhorn 350/400 factory posi
twich3136 is offline   Reply With Quote
Old 10-25-2015, 11:48 PM   #6
Coach
Coach's Avatar
Re: Motor Oil
Red Line oil also has the additional zinc needed for flat tappet cams, so you don't have to use an additional additive.
1967 Chevy C10 Stepside SWB - 350/700r4
Coach is offline   Reply With Quote
Old 10-26-2015, 07:53 AM   #7
67 chevelle
67 chevelle's Avatar
Re: Motor Oil
Rotella + lucas additive here , you realy only need the additive for breakin , if you use rotella
68 Long Fleet , ly6 , turbo 350 , 3-5 drop , original paint , front discs
67 Small window , 7 foot bed , tweaked 6.0 LSX 2004R Medium Olive
58 Apache fleet , 235 , offy intake , dual exhaust , 4 on the floor , red/white
69 Long Fleet , Custom , 6.0, 4l60 , AC , Medium Olive
67 chevelle is offline   Reply With Quote
Old 10-26-2015, 09:08 AM   #8
engineer_gregh
engineer_gregh's Avatar
Re: Motor Oil
I use Comp Cams break in oil. I talked with Comp Cams and the only difference in their regular oil and break in oil is the levels of zinc. The break in oil by the case at Amazon is typically $63.99, I'm not running a catalytic converter, so I'm comfortable just sticking with the break in oil. I've got close to 7K miles on my rebuilt 402 with no issues. This can be a touchy subject for some, so this is just my .02 cents or in this case $63.99.
1971 Longbed BB Cheyenne Super
1972 Longbed SB Cheyenne Super
1972 Longbed Highlander Custom Deluxe
1975 K5 4x4 full convertible
Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=645165
Greg Smyrna TN
engineer_gregh is offline   Reply With Quote
Old 10-26-2015, 09:12 AM   #9
Valarius_Starchaser
Valarius_Starchaser's Avatar
Re: Motor Oil
I always run an additive with 10w30 Valvoline after my last flat tappet cam got destroyed in my mind the extra insurance is still cheaper than a whole rebuild and the time involved
Valarius_Starchaser is offline   Reply With Quote
Old 10-26-2015, 10:41 PM   #10
mike16
Re: Motor Oil
lycoming and Continental aircraft companies sell an engin oil supliment, typcally available through FBO's or vendor who cater to general aviation. approved by the manufacturer and the FAA.
mike16 is offline   Reply With Quote
Old 10-28-2015, 11:04 PM   #11
toolboxchev
Re: Motor Oil
That is interesting, I have a friend who has a few planes. I know about the av gas also. Seems to me the true things we had as fuel and oil is only available through the aviation world.
