327 what flywheel and clutch?
Collecting all the parts to swap from my current 292 to a large journal 327. I just read that the flywheel on the 292 is different than the small block V8's. What flywheel and clutch should I be looking for? I'm going to keep the SM465. Also any potential issues with the bell housing I currently have? Thanks
'66 C10 SWB '64 C2 roadster '38 Indian Scout Flattracker '70 Triumph T120R '81 Laverda Jota |
Re: 327 what flywheel and clutch?
Bell housing will bolt right on as for the flywheel every thing I read says it will also fit as long as yours is a "292" smaller 6s had smaller bolts and will fit the 327 if you drill them out.... as for the clutch if yours is 11" then it will also be fine
![]() Join Date: Sep 2006
"A man and his truck, what a beautiful thing" 65 Short Fleetside BBC 65 Long Fleetside 283 3 on the tree for now. my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536 |
#4 | |
You could count the teeth on the flywheel you have now. If you have 168 then it will work.
