Old 11-22-2015, 05:19 PM   #1
61K10
61K10's Avatar
longer wheel studs?
anybody make longer wheel studs for a chevy/gmc/blazer that go through the disc rotor? would like 1/2" more in length. have some heavy duty lugs and the studs only go through half way.
1961 chevy K10
my build is------------61K10 build
61K10 is offline   Reply With Quote
Old 11-22-2015, 05:54 PM   #2
Brad54
Brad54's Avatar
Re: longer wheel studs?
Find a really good parts store, and ask to see their Dorman catalog.
My local store has a wall of Dorman organizers and several are full of wheels studs.
You'll need overall length, stud diameter, and shoulder diameter.
The shoulder diameter will be the make-or-break for the swap. They make several different sizes, and it's got to be really close to what you've got now or it's a no-go.
If they don't have them in the store, they should be able to order them for you.
In the past, I've just taken the old one in and they matched it with the dial caliper at the counter.
Easy-peasy, if you don't deal with a guy who is lost without The Parts Computer!
-Brad
'61 Suburban daily driver: off the road due to 180-pound 8-pt buck!
'62 K-10 long-step project
'61 C30 Camper, aka "Valdez"
There's no cool like Old School
Brad54 is offline   Reply With Quote
Old 11-24-2015, 06:56 PM   #3
maxwoof
Rockauto.com has a number of them - under tools and universal parts, as well as by various truck model.
maxwoof is offline   Reply With Quote
Old 11-25-2015, 01:40 PM   #4
61K10
61K10's Avatar
the only ones i have found and are for a Bronco which are 1/2" not 7/16. could be made to work but are $75 for just 5------------
1961 chevy K10
Old 11-25-2015, 02:04 PM   #5
kwmech
The only way is to upgrade to a 1/2'' stud and drill out both the rotor and the hub and press the 2 back together. I do it all the time for my customers that run larger tires and pop the small 7/16'' studs. Some even step up to the 9/16 studs with their 6 lug
Old 11-26-2015, 02:26 PM   #6
61K10
61K10's Avatar
thanks kwmech--I figured that was the only way to do it with 1/2" studs. I have new 7/16 studs as the rotors are new. part # for the studs? maybe i will just bring them up to ya. I also need my axle stub shafts bearing surface turned down a few thou. pm me if you can do this work.
1961 chevy K10
