Old 11-29-2015, 03:03 PM   #1
RB72
Original motor?
I'm taking my valve covers off today to replace the gaskets. I've heard that you can find numbers somewhere in there that will tell me where my motor was made at. Does anyone have any more information on where they would be at or anything else? Thanks!
RB72 is offline   Reply With Quote
Old 11-29-2015, 03:25 PM   #2
leftybass209
leftybass209's Avatar
Re: Original motor?
The casting numbers on the cylinder heads, will only tell you what the cylinder heads are from. The number on the block, behind the drivers side cylinder head will tell you what your engine is from.
I like this list for cylinder heads
http://www.nastyz28.com/sbchevy/sbch.php
This is where the engine id is found
http://speednik.com/files/2013/09/chevyasylum-com.jpg
leftybass209 is offline   Reply With Quote
Old 11-29-2015, 03:53 PM   #3
GRX
GRX's Avatar
Re: Original motor?
Those raised "casting numbers" will give a general idea of when or what. For the where, and more specifics, you need the stamped suffix numbers on the front pad. Look at the image and see the link below:
http://www.nastyz28.com/chevy-engine-code-stampings.php
1969 c-10 Step Side Long Bed. I-6 250cid = = 1969 Pontiac GTO hard top. 400, 4-speed.
GRX is offline   Reply With Quote
Old 11-29-2015, 04:21 PM   #4
davepl
davepl's Avatar
Re: Original motor?
^^^ Sadly, no. There is no VIN suffix on the trucks.
The three letter code will tell you what year and transmissions of truck (or non-truck) it came with. That, combined with a reasonable looking date code, is as close as you can get.
The trucks do not have a serial or sequence number stamped on them. So for mine, I can decode to "1970 Truck 402 w/ TH400" and see that the engine is dated a couple of months prior to the truck build, so it's probably original. But you can never prove it conclusively.
1970 GMC Sierra Grande Custom Camper - Built, not Bought
1969 Pontiac 2+2 427/390 4-speed Coupe
1969 Pontiac 2+2 427/390 4-speed Convertible
davepl is offline   Reply With Quote
Old 11-29-2015, 07:46 PM   #5
GRX
GRX's Avatar
Re: Original motor?
Thanks for the correction^^^
Knew that but had forgotten. I work with cars more than trucks actually.
Old 11-29-2015, 08:36 PM   #6
RB72
Re: Original motor?
I think I found the casting number... It's 338882. Does that sound right?
Old 11-29-2015, 08:59 PM   #7
toolboxchev
Re: Original motor?
That 882 number is off your heads?, most likely not original yet chevy later year. Check those against the links for the specs.
1970-80 333882 350,400 1.94 1.5 76 cc is that correct???????
toolboxchev is offline   Reply With Quote
Old 11-29-2015, 09:01 PM   #8
GRX
GRX's Avatar
Re: Original motor?
Probably 333882. See thread linked below.
http://67-72chevytrucks.com/vboard/s...d.php?t=261243
