Old 03-30-2016, 10:27 AM   #1
blazer2007
upper ball joint with rivets ?
I need to replace upper ball joints on 1980 2wheel dr. half ton and they still have the rivets.Should I invest in a air chisel or will a grinder work.I need to do this in a afternoon so I,m just trying to get all my ducks in a row.Any other pitfalls I might encounter on this project ?
blazer2007 is offline   Reply With Quote
Old 03-30-2016, 10:44 AM   #2
cdowns
cdowns's Avatar
Re: upper ball joint with rivets ?
I've always just wacked them off witj my handy diegrinder in about a minute a piece
Old 03-30-2016, 11:03 AM   #3
chevy_mike
Never Ending Projects
chevy_mike's Avatar
You can grind the rivets down but you'll likely still need a punch and hammer to knock them out. I tend to use a cutoff wheel and make an X pattern through the head and then use my air chisel to knock off the pieces and then put in a drift punch into the air chisel to punch them out.
1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD
1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD
1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD
We were given two ears and one mouth for a reason... listen twice as much and speak half as often...
chevy_mike is offline   Reply With Quote
