Brake shoe anchor
My son snapped the brake drum anchor pin bolt on his truck. I have searched online and cant find a replacement. I can find one for chevelle and Camaros but none for the c10. Any idea where I can go to find one or anyone have one laying around?
1970 GMC truck ![]() 1988 Harley 1200 Sportster ![]() |
Re: Brake shoe anchor
Any parts store, just tell them you need a drum brake hardware kit for your model year. I think I got my kit from Autozone for 10 bucks, has all the hardware including springs.
1970 C-10 LWB 1998 Jeep Wrangled TJ 2009 Honda VTX 1300 2013 Buick Enclave |
You would think. But no not this part. This bolts to the backing plate. Here is a picture of the broken pin.
![]() Join Date: Jun 2009
I have a couple of them if you can tell me how to get them out
Larry It is easily overlooked that what is now called vintage was once brand new. "Project 68" paypal.me/ldgrant |
Aren't they part of the backing plate? The easiest and fastest would be to get a replacement backing plate from a like vehicle.
Remove the rear diff cover Remove the C-Clip Pull the axle Pull the seal/bearing Unscrew the brake line Remove the wheel cylinder Unbolt the backing plate. Install is reverse.
1970 GMC K2500 Dis-use is harder on a car than mis-use. |
Some of them have a large nut on the back of the backing plate. If so, remove this nut & tap out the anchor pin. You should be able to find one at a salvage yard. If it is built in to the plate you will need to replace the backing plate.
#7 | |
You're right! Now that I look at the picture he attached again, it looks like his may be the "nut" version. Howdy neighbor!
Snap a pic of the pumpkin and the backing plate, load up the tools and go to the nearest picnpull in DFW. Go to the truck section and pull what you want.
I got two of them for you, they are threaded into it. A good torch with some heat and a heavy impact took it out.
