Old 10-09-2016, 11:44 PM   #1
ecna
Engine Stands
Can someone confirm left/right engine stands for a SBC. Attached is a pic as I think it should be. Does that look correct or is it reversed and should curve forward? Thanks.
ecna is offline   Reply With Quote
Old 10-10-2016, 06:51 AM   #2
Zeroman
Zeroman's Avatar
Re: Engine Stands
ecna, check out the thread about the frame pictures. There are many shots of the engine stands, probably answers your question.
http://67-72chevytrucks.com/vboard/s...d.php?t=700421
Zeroman is offline   Reply With Quote
Old 10-10-2016, 11:27 PM   #3
ecna
Re: Engine Stands
I have literally spent hours reading engine mount threads. I also just went through the link you posted. There is one kinda decent shot but not enough from above to see the angle. With all the experience in this board, I thought identifying left from right would be an easy question. Thanks for the link though.
Old 10-11-2016, 08:33 AM   #4
biketopia
Re: Engine Stands
I can look at mine this evening and get you a pic if needed.
71 c-10 Long Bed, under the knife for a No Limit Engineering Wide Ride Chassis Pack and coil over static drop.
07 Silverado Classic 2wd
95 Camaro 427SBC/TH350
biketopia is offline   Reply With Quote
Old 10-11-2016, 12:40 PM   #5
ecna
Re: Engine Stands
That would be great. Thank you.
Look at my pic, you can see the way I have it (and think it fits best) it turns towards the back of the truck. If I flip them, they turn towards the front of the truck. The holes in the frame have been welded closed as it had a different mount system installed previously, otherwise it might me much more clear. Obviously I want them correct before I drill holes.
Old 10-11-2016, 01:55 PM   #6
BugzC10
BugzC10's Avatar
Re: Engine Stands
They point towards the rear like you have it positioned.
1970 C10 Short Stepper with 71/72 front clip.
BugzC10 is offline   Reply With Quote
Old 10-11-2016, 11:10 PM   #7
ecna
Re: Engine Stands
Thank you!
Old 10-11-2016, 10:59 PM   #8
67c10rustbuket
67c10rustbuket's Avatar
Re: Engine Stands
Looks correct to me. Here's mine.
Dan <---(my name)
67 SWB C10 project "GEORGIA"-59 Brookwood 2dr wag...Next project-03 Tahoe 4x4 5.3 family ride-07 Hondur Accord, commuter car
67c10rustbuket is offline   Reply With Quote
Old 10-11-2016, 11:11 PM   #9
ecna
Re: Engine Stands
Wow. Clean frame. Thank you!
Old 10-12-2016, 09:06 AM   #10
biketopia
Re: Engine Stands
Looks like you got what you needed, I got home later than expected last night and it was dark by the time I got out to the yard.
Old 10-12-2016, 11:24 PM   #11
ecna
Re: Engine Stands
No problem. I appreciate the thought.
