Old 02-21-2017, 12:37 AM   #1
72kool
72kool's Avatar
New engine questions
I have been weighing the options for engines between rebuild or crate and it just seems that crate is the way to go.
I am looking at an engine from summit and have some questions about it.
https://m.summitracing.com/parts/nal...53/none/images
Have any of you used this engine? Any feedback?
Also I have a craving for some good power. I'm not wanting a lot but noticeable from stock.
My question is, I have a chevy bowtie intake 14096242
http://m.ebay.com/itm/Mercruiser-5-7...257Ciid%253A20
What would be a good cam to mate with this intake to maximize hp and what could I expect to get out of this setup ?
The reason I ask about this intake is because I have it and if I can get reasonably more than stock with a good cam then I would like to use it. If it won't gain much, I don't want to spend that much extra for a new cam and new intake because I'm on a tight budget
Would I be better off just putting my stock parts on and leaving this engine in stock configuration?
1972 GMC C20 Custom Camper 350/TH350
72kool is offline   Reply With Quote
Old 02-21-2017, 01:48 AM   #2
El Dorado Jim
Re: New engine questions
http://67-72chevytrucks.com/vboard/s...d.php?t=729675 check out this thread... look about 8 threads down from yours
El Dorado Jim is offline   Reply With Quote
Old 02-21-2017, 08:11 PM   #3
garyd1961
I hate to sound like an azz but if you want HP you bought the wrong engine. With the old style heads and low compression it will never be a power house. I'm not saying it's not a good motor, just that it will never win any trophies at the tract.
garyd1961 is offline   Reply With Quote
Old 02-21-2017, 08:41 PM   #4
bigmac73
bigmac73's Avatar
I am curious since you live in Kearney ,Nebraska why are you not looking at a local source Blue Print engines??
and if you did i am curious on your opinion since you live in the same town
Mike
72 C-10 Cheyenne off frame resto and Upgraded to 4 wheel disk, Tilt, Dakota Digital Dash / Rear slider.
421 SBC / TH350 3000RPM Stall
Progression Ignition /Holley 750 DP/3:73 gear Eaton Limited Slip unit / 2 1/2 exhaust glasspacks
bigmac73 is offline   Reply With Quote
Old 02-21-2017, 08:42 PM   #5
bigmac73
bigmac73's Avatar
that intake is a boat anchor
Mike
