Old 09-01-2017, 06:59 PM   #1
tim71
tim71's Avatar
Wiper transmission arm question
Is there a trick to getting this clip to secure itself to the post that holds both wiper transmission arms? I've spent a lot of time on what is probably a 20 second job.
1972 Blazer Highlander
1971 GMC K1500 SWB (sold)
2004 Corvette Z06 CE
tim71 is offline   Reply With Quote
Old 09-01-2017, 07:28 PM   #2
71CHEVYSHORTBED402
71CHEVYSHORTBED402's Avatar
Re: Wiper transmission arm question
Insert the clip into the pin from the top. Should be real easy. Perhaps the arms aren't assembled right? Anyway, it should look like this.
Incidentally Tim, if you haven't got one of these or similar, this tool is the stuff for pulling & attaching wiper arms. It will make your life easier and is damage prevention. https://store.snapon.com/Window-and-...l-P636287.aspx
Tony
71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025
71CHEVYSHORTBED402 is offline   Reply With Quote
Old 09-01-2017, 07:35 PM   #3
AussieinNC
Moderator
AussieinNC's Avatar
The clip in your pic is missing the retainer turn up...it may fit on but it will fall off when you start using it.
The bottom photo clip shows the little bend on the end that retains the clip.
AussieinNC is offline   Reply With Quote
Old 09-02-2017, 07:17 AM   #4
tim71
tim71's Avatar
Thanks for the help, I can see how to install it now.
