Old 11-24-2017, 01:55 PM   #1
OldGyrene
OldGyrene's Avatar
Thumbs up 2 piece drive shaft with TH350: yoke question
Installed a TH350 trans into my '63 LWB Fleetside, and want to keep the 2 piece drive shaft. With the carrier bearing installed on the drive shaft, it looks to me like you would need a 2 piece (ubolt/strap style) yoke at the tranny end to be able to remove the drive shaft.
Am I looking at this right ? If so, the only 2 piece 27 spline yokes I see are 1310 series ujoints and the stock drive shaft is 1350 series at the front. I guess you could use a 1310/1350 combo ujoint.
Anyone done this ?
Jake
Old fart in Western NE
OldGyrene is offline   Reply With Quote
Old 11-24-2017, 08:00 PM   #2
PGSigns
PGSigns's Avatar
Re: 2 piece drive shaft with TH350: yoke question
When you pull the shaft just pull it just like you do now. Pull the entire shaft. No need for a special yoke.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 11-25-2017, 08:35 AM   #3
OldGyrene
OldGyrene's Avatar
Jimmy
The back piece will drop as normal, but once you put a slip yoke on the front piece to the tranny, there will not be room to slide it back: the carrier bearing (see below) will not pass through the cross member and allow room to slide back and drop off.
Maybe I'm not explaining this well, but thanks anyway
Jake
Old 11-25-2017, 02:56 PM   #4
61K10
61K10's Avatar
I under stand what you are saying. been awhile sense I've had a 2-piece d/s. I take it you removed a tk 4/sp right? Corvette used one of these yokes in the 60's. A bit pricey and you would need the combo u-joint.
1961 chevy K10
my build is------------61K10 build
61K10 is offline   Reply With Quote
Old 11-26-2017, 08:13 AM   #5
OldGyrene
OldGyrene's Avatar
Yeah, that was the only 2 piece yoke I found, too. Thanks
Jake
Old 11-25-2017, 08:42 PM   #6
PGSigns
PGSigns's Avatar
I have the same bearing in my truck. I just straightened up the little tabs on the bottom plate and I slip the clamp off. Goes in and out just fine.
Jimmy
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
Old 11-26-2017, 12:19 AM   #7
Captainfab
60-66 Nut
This.....you simply remove the metal mount from the rubber and then it will pass thru the trailing arm crossmember.
Jimmy
Old 11-26-2017, 08:16 AM   #8
OldGyrene
OldGyrene's Avatar
OK. Going down to the shop this morning and give it a try. I have a 2 piece laying there with the bearing still on it.
Hope you guys are right !
Jake
Old 11-26-2017, 04:55 PM   #9
OldGyrene
OldGyrene's Avatar
Thumbs up Re: 2 piece drive shaft with TH350: yoke question
Thanks, guys ! Guess I need to have my eyes re-calibrated as I sure thought that would not fit through the cross member ! Once the metal is off, it's almost like they made it to fit through there.
That's why this forum is so valuable ! Thanks again !
Jake
Old 11-27-2017, 05:57 PM   #10
rvrfoot
Yep unbolt it and it comes right out.
rvrfoot is offline   Reply With Quote
