Old 05-08-2018, 06:18 PM   #1
duke10
Active Member
duke10's Avatar
Rattle Can?
I see the term rattle can being thrown around here on the forum a lot. I understand it to mean spray paint from a can, but what kind of spray paint?
Is there a certain brand Rustoleum for instance that works best?
I just picked up a C20 that I would like to get some white paint on the top.
I also want to spray the interior door panels and was wondering which paint works best for that application?
Thanks for any replies and direction.
duke10 is offline   Reply With Quote
Old 05-08-2018, 06:24 PM   #2
71CHEVYSHORTBED402
71CHEVYSHORTBED402's Avatar
Re: Rattle Can?
IMO, skip the rattle cans and paint the areas with a gun.
Tony
71 Custom Deluxe, SWB, 2WD, 402, A/C.
I developed an assembly guide (kit) for restoring this truck from the ground up, complete with details including full hardware descriptions. Much of the info. applies to all 67-72 GM. My build thread, with some info. about the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025
71CHEVYSHORTBED402 is online now   Reply With Quote
Old 05-08-2018, 06:58 PM   #3
1968aj
Re: Rattle Can?
I would tear it down to bare frame and let it sit in your garage for several years while you restore it. NEVER MIND. I WOULD SAND IT TAPE IT RATTLE CAN IT AND DRIVE THE WHEELS OFF OF IT.
1968aj is offline   Reply With Quote
Old 05-08-2018, 08:19 PM   #4
Problems
Problems's Avatar
Re: Rattle Can?
X2
You certainly don’t need to tear it down and do a frame off resto. But a cheap HF paint gun and some single stage paint will look better, last longer, and probably be cheaper than all the rattle cans you would need to paint it.
People fear the paint gun, it’s easier than a rattle can IMO
Problems is offline   Reply With Quote
Old 05-08-2018, 08:59 PM   #5
Barnfind46
Barnfind46's Avatar
Re: Rattle Can?
If you go the spray gun rout make sure you cover everything so no overspray gets on your hood,fenders,doors,wife's car,house,neighbor's car and so on.
68' with no bells or whistles unless I add'em.
Barnfind46 is offline   Reply With Quote
Old 05-08-2018, 10:58 PM   #6
Robznob11
Robznob11's Avatar
Re: Rattle Can?
You can actually get great results if you buy OEM ( match ) paint in the rattle can. You can also get 2k clear in the spray can on line , Eastwood etc sells it. It is a 2 part just like if you use a gun. Olympic white would work well that's the color of my truck....prep it as if you were going to use a gun!
The Ghost 67 short wide full custom. 550 hp LSX, 4l80E, narrowed 9". Body dropped w/air ride!
........................ ___
.........________//__{\_____
,,,,,,,/__(⊙)___//___/__(O)_/
@disciple2.rc 💪instagram💪
LED TAILS
Robznob11 is offline   Reply With Quote
Old 05-08-2018, 11:46 PM   #7
duke10
Active Member
duke10's Avatar
Re: Rattle Can?
So just regular Rustoleum in Olympic White?
Is the OEM paint available at the dealer?
I just want this truck to look a little better than it looks right now.
Cover up some of the rust coming through the white on the roof.
This truck is a beater, just for hauling surfboards and loaning to friends.
Old 05-10-2018, 12:13 AM   #8
el_fantasma
el_fantasma's Avatar
Re: Rattle Can?
Originally Posted by Problems View Post
X2
Don’t you need a pretty powerful compressor to run a paint gun?
72 White Cheyenne, The Ghost
el_fantasma is offline   Reply With Quote
Old 05-10-2018, 08:01 AM   #9
Problems
Problems's Avatar
Re: Rattle Can?
Depends on how fast you want to paint. If your fine doing a bedside, waiting a few minutes, and repeating all the way around the truck an 8 gallon should be fine. To your point if you want to paint continuously you need a lot of air, my compressor is 80 gallons so I guess I take that for granted.
Old 05-10-2018, 09:12 AM   #10
hotwls13
Re: Rattle Can?
I have a 60gal compressor, 10.2 scfm @90psi.
Not sure it will run a paint gun well, it had a heck of a time keeping up with a blasting cabinet.
hotwls13 is offline   Reply With Quote
Old 05-10-2018, 10:50 AM   #11
Problems
Problems's Avatar
Re: Rattle Can?
That’s plenty, my gun says 7.1cfm @ 50 PSI. I run my regulator at the compressor at 90psi and then a regulator at the gun pulling it down to 30-40psi depending on what I’m spraying.
Old 05-08-2018, 08:08 PM   #12
70 shorty
Where's my beer?
70 shorty's Avatar
Re: Rattle Can?
I "rattle canned" mine and had good results. I just used Rustoleum off the shelf a Lowe's. I did it last summer and it looks just as good today, and I get compliments all the time. Does it look like a professional paint job? Not by a long shot, but it does have a shine to it, and it does look better than the primer that was on it for years.
70 C10, shortstep, .30 over 250,Hurst shifted 3 spd parts hauler. Holley 390, Clifford Intake, Header, ported cylinder head, unknown bigger cam.
79 Corvette L82, 4 spd, black, red interior, headers, flowmasters, and unkown bigger cam.
'03 Grand Cherokee Laredo, 4.0 4x4 daily driver. 165K miles, and runs great
'08 Tahoe LTZ 4x4 155K
70 shorty is offline   Reply With Quote
Old 05-08-2018, 08:18 PM   #13
rockyrivermark
Re: Rattle Can?
I brushed and rolled a '78 caprice when I was younger.
Looked awesome on rainy days.
RRM
My build page
http://67-72chevytrucks.com/vboard/s...d.php?t=764662
My cabinet building site
http://www.cbcabinets.com
rockyrivermark is offline   Reply With Quote
Old 05-09-2018, 12:05 AM   #14
71CHEVYSHORTBED402
Re: Rattle Can?
RRM
Ha, I had a 78 Caprice. Two door burgundy Classic. Nice beautiful ride until about 75K, then everything broke...............what a piece a crap.
Tony
Old 05-09-2018, 10:40 AM   #15
rockyrivermark
Re: Rattle Can?
mine went on to win a demo derby after sold it to buddy.
My build page
Old 05-09-2018, 12:19 PM   #16
71CHEVYSHORTBED402
Re: Rattle Can?
Tony
Old 05-09-2018, 01:25 PM   #17
HO455
HO455's Avatar
Re: Rattle Can?
Stick with enamel and avoid lacquer as it may react with the existing paint. Lots of thin coats, wet sand with 400 every other coat. Then buff it out when your done. A good waxing schedule will help it stay looking good over the long run. I've done several motorcycles this way.
RIP Bob Parks.
Old 05-09-2018, 12:51 AM   #18
3757chevy
3757chevy's Avatar
Re: Rattle Can?
...https://www.amazon.com/Dupli-Color-B.../dp/B004PL8LKQ GM polar white
'67 Stepside (bought 1997-sold 2021-partially bought back 2024) '96 Bronco Eddie Bauer (inherited 2010)
MIKE
3757chevy is offline   Reply With Quote
Old 05-09-2018, 09:35 AM   #19
Swar
Swar's Avatar
Re: Rattle Can?
You can buy Fast Dry gloss or flat white spray paint at Walmart for $1 a can. I primed my whole truck with it in flat black and then went over it with duplicolor black pearl. Looks pretty damn good for spray paint. Spray guns are overrated for daily drivers, because guess what happens when you get a chip or scratch? You gotta break out the touch up cans anyway.
Swar is offline   Reply With Quote
Old 05-09-2018, 10:08 AM   #20
hotwls13
Re: Rattle Can?
My vote is get some rustoleum or krylon at walmart. Pick the white closest to what u want.
I'm seriously considering painting my entire truck with Krylon. My truck is a beater, not original paint, lots of chips, dents and some rust. I plan to clean up the rust, put some bondo where needed and spray it myself. I have a compressor, mask and cheapy HF gun already (the $9.99 one). I will be painting it on the side of my house under carport (plan to put up plastic, AC filter on one end, exhaust fan on the other and wet the cement). But I still think the Rattle Cans will be easier (no mixing, no cleaning or loading spray-gun) and cheaper (figure I can paint the whole truck with 10-15 cans, $40-60).
Be aware though that if you decide in the future to repaint with automotive paint out of a gun, you will probably have to remove all the cheap rattle can stuff completely (more work).
Anyway, I say just use what's available and will look decent for a driver.
Old 05-09-2018, 10:30 AM   #21
kenr74
Re: Rattle Can?
I rattle canned an old Jeep once. Turned out looking great. I did end up using about twice as many cans as I thought I would though.
kenr74 is offline   Reply With Quote
Old 05-09-2018, 01:36 PM   #22
67chevemall
67chevemall's Avatar
Re: Rattle Can?
Tremclad flat black everything. ...
1968 Chevy C10 307 3ott fleetside
1967 Chevy C/10 V8, 3spd, fleetside lwb.Sold
1967 Chev C/10 step, 383, M21. SOLD
67chevemall is offline   Reply With Quote
Old 05-09-2018, 03:06 PM   #23
71CHEVYSHORTBED402
Re: Rattle Can?
You guys have more faith in rattle cans than I do, and might know better too. I bombed my frame long ago, front in Rustoleum and rear in Krylon. Rustoleum was the better of the two, held up surprisingly well.
Seems to me that paint through a gun is better quality. One option is a "Preval-sprayer". Though a gun is likely better, I've used them with good results, small areas only. Not sure about that cab, might need a back-up ready to go. - Take it for what it's worth, my paint experience is small.
Tony
Old 05-09-2018, 04:23 PM   #24
Robznob11
Robznob11's Avatar
Re: Rattle Can?
Fwiw....I had a 99 white grand am a chunk of paint the size of my hand came off the roof. I went sanded the primer and shot it with the SEM and blended it out. After several coats I went sanded and buffed the area. When I sold it the dealership did not even catch the fix.
LED TAILS
Old 05-09-2018, 05:01 PM   #25
hotwls13
Re: Rattle Can?
I'd be interested in seeing a breakdown of the costs involved to do a cheapy scuff and spray with rattle can vs doing it with automotive single stage kit.
About 10 years ago, my Dad had a late 70's stepside he picked up for $1100 and drove it home. It was an ugly flat purple color and the only color he likes is black. On the drive home from picking it up, he stopped at walmart and bought about 15 cans of Krylon Satin Black (he was going for rustoleum, but Krylon was $1 per can cheaper).
Once home, Me, my Dad and my 15yr old Son, scuffed the purple paint with red scotchbrite pads, taped it off with blue masking tape and newspaper. Wiped it down with some damp towels. Air bombed the whole thing right there in the driveway under a carport. We put 3 coats on it. There were a few runs and we missed a few spots (that were easily patched later). My Dad drove that truck for a few Years, sold it to another guy who drove it a couple and then my Dad bought it back again, drove it for a couple more. As far as I know it's still running around with the krylon paint job (my dad recently sold it again). Looked like a black primered/satin'd truck. Nothing fancy but night and day difference from the previous paint.
Found the pics. Looks like it was 8yrs ago and it was a 73.
