![]() ![]() Join Date: Mar 2016
Rear Shock Relocation Bracket (my version)
Thought I would share my latest project on my 67 step side rear shock brackets . I saw these first back in 2011 http://67-72chevytrucks.com/vboard/s...d.php?t=451200 but I had an Idea that I could make them more appealing to the eye and with less material.
'35 1/2 ton Pickup (bought 2020) '68 C10 Suburban (bought 2021) '72 K5 Blazer (bought 2013) '67 Stepside (bought 1997-sold 2021) '96 Bronco Eddie Bauer (inherited 2010) My 1st day here-'67 C10(sold)and '72 K5 Blazer http://67-72chevytrucks.com/vboard/s...d.php?t=702056 "Another Blue Chevy"(1935) http://67-72chevytrucks.com/vboard/s...d.php?t=799203 ![]() ![]() |
Re: Rear Shock Relocation Bracket (my version)
The first picture is the original plans that I borrowed . Saved it in the paint program , modified it to my liking and printed up my plans. The best part is that I was able to use a piece of scrap 2" X 2" tubing. Now all I have to do is drill out the rivets and mount them up.
'35 1/2 ton Pickup (bought 2020) '68 C10 Suburban (bought 2021) '72 K5 Blazer (bought 2013) '67 Stepside (bought 1997-sold 2021) '96 Bronco Eddie Bauer (inherited 2010) My 1st day here-'67 C10(sold)and '72 K5 Blazer http://67-72chevytrucks.com/vboard/s...d.php?t=702056 "Another Blue Chevy"(1935) http://67-72chevytrucks.com/vboard/s...d.php?t=799203 ![]() ![]() Last edited by 3757chevy; 05-15-2018 at 01:58 PM. |
Got some lower brackets from member TXLSX
Got the lower brackets painted , still need to install them and the uppers . I've replaced the power steering pump and hoses last week, replacing steering gear box this week. And working on a different shifter .
Cooo000oo000ooollll! Nice!
'35 1/2 ton Pickup (bought 2020) '68 C10 Suburban (bought 2021) '72 K5 Blazer (bought 2013) '67 Stepside (bought 1997-sold 2021) '96 Bronco Eddie Bauer (inherited 2010) My 1st day here-'67 C10(sold)and '72 K5 Blazer http://67-72chevytrucks.com/vboard/s...d.php?t=702056 "Another Blue Chevy"(1935) http://67-72chevytrucks.com/vboard/s...d.php?t=799203 ![]() ![]() Last edited by 3757chevy; 07-09-2018 at 12:06 AM. |
Well the truck is back together. including my shifter . I had to get rid of the mustang shifter that had been given to me eleven years ago. Now I have Hurst Pro-matic 2 ratchet shifter built into the floor. Here's a link to my shifter box build. http://67-72chevytrucks.com/vboard/s...d.php?t=767127
'35 1/2 ton Pickup (bought 2020) '68 C10 Suburban (bought 2021) '72 K5 Blazer (bought 2013) '67 Stepside (bought 1997-sold 2021) '96 Bronco Eddie Bauer (inherited 2010) My 1st day here-'67 C10(sold)and '72 K5 Blazer http://67-72chevytrucks.com/vboard/s...d.php?t=702056 "Another Blue Chevy"(1935) http://67-72chevytrucks.com/vboard/s...d.php?t=799203 ![]() ![]() Last edited by 3757chevy; 07-10-2018 at 09:31 PM. |
Haha too much fun I see! Those real wood peices on the dash? Neat!
Yep. Thanks , here is a link to a post of my dash http://67-72chevytrucks.com/vboard/s...3&postcount=91 before my windshield was replaced.
Two months of planning, other fixes
![]() Join Date: Feb 2016
Looking forward to seeing the end results!
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. ![]() RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
... Me too, I hope my next weekend I can get 'r ' done.
Well it is Monday. I got the upper brackets installed.This is the rivets I needed to grind and drill out. And a view of the old brackets and shock angles.
My 1st mistake was to not get my own measurement for the mount to frame. It should have been 6" not 5-5/8".(blue arrow in the 1st pic and yellow in the 3rd) My 2nd mistake was to drill my shock mounting holes at 1" not 3/4" from the end (yellow arrow) which caused the head of the mounting bolt to get in the way of the shock . So I grabbed a 7/16" bumper bolt to mount the rear of the bracket to the frame.
'35 1/2 ton Pickup (bought 2020) '68 C10 Suburban (bought 2021) '72 K5 Blazer (bought 2013) '67 Stepside (bought 1997-sold 2021) '96 Bronco Eddie Bauer (inherited 2010) My 1st day here-'67 C10(sold)and '72 K5 Blazer http://67-72chevytrucks.com/vboard/s...d.php?t=702056 "Another Blue Chevy"(1935) http://67-72chevytrucks.com/vboard/s...d.php?t=799203 ![]() ![]() Last edited by 3757chevy; 08-28-2018 at 01:07 AM. |
#15 |
Installed
#16 |
Good job! I really like that you removed the bed floor so you could get us good photos of your installation. A couple of questions if you would be so kind. How close does the shock body come to the axle housing? And you did use the stock lowers?
Thanks again.
#17 |
Thanks. I have a 1/2" sheet of plywood (held down with a 5/16" nut and flat washer on stud in center of the bed ,see arrow) for my bed floor for now, so it's easy access. The lower shock body has a good 1/2" clearance to the axle . I have not changed my lower brackets yet. I'm thinking about using a 1" lowering block on the rear and I want to replace the u-bolts either way.
#18 |
I got things cleaned up a bit, touched up my bed liner and put my plywood back in for now.
#19 |
I took out the rest of the bed wood (not much left) and metal strips and tucked the plywood under the angle strips. It looks a little better that way.
#20 |
I have got my wood cut, placement chosen and now the sanding . Kinda like snowball effect, I keep finding things to work on.
'35 1/2 ton Pickup (bought 2020) '68 C10 Suburban (bought 2021) '72 K5 Blazer (bought 2013) '67 Stepside (bought 1997-sold 2021) '96 Bronco Eddie Bauer (inherited 2010) My 1st day here-'67 C10(sold)and '72 K5 Blazer http://67-72chevytrucks.com/vboard/s...d.php?t=702056 "Another Blue Chevy"(1935) http://67-72chevytrucks.com/vboard/s...d.php?t=799203 ![]() ![]() Last edited by 3757chevy; 07-14-2019 at 12:01 AM. |
