Old 05-26-2018, 07:09 PM   #1
wpavlis
Front brake drum rivet removal
On my 68 the drums were still riveted to the hub. I ground off the end on the drum side and got the drum off. How do I get the rest of the rivet out. I have been pounding on them with a drift with no luck. I tried drilling one out, but a battery powered drill just isn't cutting it. I am thinking some heat might help. How have others done this? Thanks!
wpavlis is offline   Reply With Quote
Old 05-26-2018, 07:50 PM   #2
BCOWANWHEELS
Re: Front brake drum rivet removal
leave them in, no big deal
I BELIEVE IN JOHN 3:16
BCOWANWHEELS is offline   Reply With Quote
Old 05-26-2018, 09:58 PM   #3
hewittca
hewittca's Avatar
I just left them in on mine, but I think it's too late for you to do that since you've been pounding on them. If you can get a grinder in there, you can grind it smooth and then usually the remaining portion of the rivet is pretty easy to knock out with a punch.
Builds: Green Gus the 68 C10 | Bluey the 72 1500 | Lowly the 70 C10
Instagram: @dr.hewitt
C10 Concept/Development Photos: Master Thread
hewittca is offline   Reply With Quote
Old 05-26-2018, 10:47 PM   #4
wpavlis
Thank you both for the help. After the face palm moment I tried the new drums and the do fit. They are apparently particular about their orientation now but that's fine. I really only tried drilling one out so I just cleaned it up a bit and it seems to work fine. Put the new bearing races in so now it's ready to reassemble. Thanks for the help!
