09-12-2018, 01:56 PM | #1 |
Sway bar from 86
I hear the 73 to 87 sway bars fit our trucks.
Can someone confirm this as I finally found one. Local wrecker has one.
1968 Chevy C10 307 3ott fleetside 1967 Chevy C/10 V8, 3spd, fleetside lwb.Sold 1967 Chev C/10 step, 383, M21. SOLD |
09-12-2018, 03:18 PM | #2 |
Re: Sway bar from 86
Yes, two wheel drive. Up to 91 on V series trucks and Suburbans.
09-12-2018, 03:33 PM | #3 |
I have a '76 front swaybar from the pick-n-pull on my truck.
1972 C10 LWB, 350/350 Deconstruction began 5/2009, mostly completed restoration, 5/2017 |
09-12-2018, 06:42 PM | #4 |
I have a 1 1/4" sway bar from a 1 ton 78 on mine
1967custom |
09-12-2018, 07:56 PM | #5 |
I've used one from an 87 1 ton on my truck. Make sure you get the clamps as well, since the 1.25" bars take bigger bushings/clamps than the smaller sizes.
09-12-2018, 08:00 PM | #6 |
I have one on my 68.
Do not get one from a Chevy or GMC van!Way too wide to fit! Mike. |
09-13-2018, 02:11 PM | #7 |
70+ ( Old Skool Club )
Yes they definitely fit as I've done a ouple of them. You say you have one already and it will work but the ideal one to get is a 1 1/4 inch one from a C30 or GMC 3500 1 ton truck. I'd also buy new polyurethane bushing to install as well. Here is link to a very detailed front sway bar install.
http://67-72chevytrucks.com/vboard/s...ad.php?t=72338
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " Circumsatances Do Not Change Responsibility " " The Sky is not the Limit, Your Mind is." Marilyn Monroe .. RIP Charlie Watts 1941 - 2021 |
09-14-2018, 09:21 AM | #8 |
Nice thanks.
Not sure what size it is. From a 77 2wd
09-14-2018, 10:17 AM | #9 |
be sure to measure the thickness of yours as the bushings are different. theres 7/8, 1", 1 1/16, 1 1/8 and 1 1/4
1967custom |
09-14-2018, 10:50 AM | #10 |
Wow 5 different sizes..thanks for the heads up
