10-12-2018, 12:41 AM | #1 |
Suburban. Don’t know year
Are these Suburbans very common? I was sent these pics by a friend. I was expecting a 1973 4wd but this is an older what appears to be 2wd. Interesting.
Posted via Mobile Device |
10-12-2018, 01:09 AM | #2 |
Re: Suburban. Don’t know year
I'd jump on it if I was looking for a project.
I have a '67 K/10 Suburban that I need to rebuild already. As far as 'rare' -- I've seen literature stating that only ~166 K/10 [4WD, Half ton] Suburbans were produced in Model Year 1967. Numbers would increase as the production run progressed. Mine had a 454 a PO had shoehorned in. It would pass anything on the road but a gas station. The 'Barn Doors' are desirable, but I like the lift/tailgate myself. Tailgates are handy for a small gas grill BBQ. Body appears straight. Dings are not major. Looks like a '68 C/1500, judging by the presence of side reflector markers and the angle of the leading edge of the hood. The 3-door set up was only made during the 67-72 run. Any 4-door Subs of the period were custom jobs. [Once saw one in a parking lot ... the guy had faked-in a Door #4, with a phoney outside door handle and painted-on door lines.] Being a GMC is a plus, they were higher optioned usually. Looks repainted in yellow. Was it a school bus in a small community once? Cool find. Could be a fun project. Good luck.
Every 25 years I like to rebuild that 292, whether it needs it or not. Last edited by '68OrangeSunshine; 10-12-2018 at 01:20 AM. |
10-12-2018, 10:16 AM | #3 |
Slant nose with marker lights. It should be a 1968.
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
10-12-2018, 04:33 PM | #4 | |
I was told it was owned by a school. Correct. Can be had pretty reasonably under 500 I think but I prefer 4wd. I think 6 cyl. Thanks. Posted via Mobile Device |
10-12-2018, 07:21 PM | #5 | |
To make a C truck into a K truck, you pretty much have to find the 4x4 frame and swap the body over. Four wheel drive Subs were rare. I think the Suburban's 127'' wheelbase was in common with longbed fleetside pickups, but I'm not positive. With a front winch and a positraction rearend, it would probably go anywhere. I'd go for it.
Every 25 years I like to rebuild that 292, whether it needs it or not. Last edited by '68OrangeSunshine; 10-19-2018 at 12:43 PM. Reason: correction |
10-19-2018, 09:15 AM | #6 |
Just find a 4x4 chassis and take all the bracketed and put it on that frame, GM was smart for the most part and already drilled all the wholes to make a truck either 4x4 or 2wd, just mattered what they bolted on. Pickup chassis are a little different for the body mounting. They are the same 127 in wheel base but the curves and mounting bracketry are different.
10-20-2018, 06:55 AM | #7 |
What’s the interior like?
