Old 08-08-2019, 02:08 AM   #1
stilldreamin6772
Wide band 02?
Here's my rundown. 2000 vortec 6.0, 4l80 trans with speed engineering headders and there xpipe. My question is where do I put the wide band 02 sensor. Do I need a duel sensor or am I able to put one in. Thanks in advance
stilldreamin6772 is offline   Reply With Quote
Old 08-08-2019, 07:15 AM   #2
rpmerf
rpmerf's Avatar
Re: Wide band 02?
From what I've read...
Should be about 3' from the closest cylinder. Too close and it gets too hot, too far away and it gets too cold. You want it at least 6" after the collector. You want ti in a piece of pipe that is straight for at least 6", as bends can interrupt flow. Should be at least 15* above parallel to the ground.
You can run 1 sensor after one header, or one after each header. Up to you. Both sides SHOULD be pretty even.
If you google around "wideband location" you will get tons of results.
1970 C20 Custom Camper - 350, TH350
1997 GMC Suburban
1994 Acura Integra GSR
1987 Dodge Daytona Shelby Z
rpmerf is offline   Reply With Quote
Old 08-09-2019, 02:47 PM   #3
sprint_9
sprint_9's Avatar
Re: Wide band 02?
3 to 18 inches from the collector seems to be a popular answer.
Run a wideband in addition to your stock sensors.
sprint_9 is offline   Reply With Quote
Old 08-25-2019, 11:02 PM   #4
Gregski
Gregski's Avatar
Re: Wide band 02?
fugly, yes! but effective, I plan on running two Wideband AEM O2 sensors in addition to my narrow band sensors at all times, and when not just plug the second bungs with a plug (you don't want to leave O2 sensors in disconnected without heating them up as they will get ruined)
2.5" dual exhaust made out of all GM 2500 3/4 donor truck intermediate pipes and Suburban over the axle tail pipes
Gregski is online now   Reply With Quote
