01-03-2020, 07:28 PM | #1 |
Axle GM 12 Bolt Rear end ID help
3817778 11-41 gm 12 65. Can someone De code please. I have a 1957 Chevy 3600 4x4 I’m rebuilding. Didn’t look good when I pulled the cover Looks like it’s getting rebuild
01-03-2020, 07:34 PM | #2 |
Re: Axle GM 12 Bolt Rear end ID help
[QUOTE=Bridgeman57;8653941]3817778 11-41 gm 12 65. Can someone De code please. I have a 1957 Chevy 3600 4x4 I’m rebuilding. Didn’t look good when I pulled the cover ���� Looks like it’s getting rebuild
01-03-2020, 07:35 PM | #3 |
3.73 gear ratio....open diff
01-03-2020, 07:37 PM | #4 |
Any clue what year??
01-03-2020, 07:45 PM | #5 |
There should be numbers on the axle tube on pass side...but they'll only show month and day built...not yr
01-03-2020, 07:47 PM | #6 |
Negative. Axles don’t show no numbers. They are wiped out. Need to figure out what year axle I have so I can spend some money
01-03-2020, 07:57 PM | #7 |
You mean axle or axle tube?...the numbers I'm referring are on the tube...
01-03-2020, 09:25 PM | #8 |
After removing about an inch of grime. It says KDA 175 2
01-03-2020, 09:32 PM | #9 |
first post has 12 65 = 12th month of 1965 mfd for the gear set .
77-k30lb BIG truck build . 87-k30lb budget beater build . 85-k30lb the plow machine build . 85-c10sb summer fun toy . ----------------------------- HOLLEY SNIPER efi = worst case of p.i.t.a i ever had . EDELBROCK pro flo 4 = best deal going so far . love my setup works great. |
01-03-2020, 10:07 PM | #10 |
KD shows to be 2.73...but the 11-41 on r&p is 3.73
A should be assembly plant...but I'm not showing a A plant 175 is 175 day of yr is June 24 2 is 2nd shift
Mongo...aka Greg RIP Dad RIP Jesse 1981 C30 LQ9 NV4500..http://67-72chevytrucks.com/vboard/s...d.php?t=753598 Mongos AD- LS3 TR6060...http://67-72chevytrucks.com/vboard/s...34#post8522334 Columbus..the 1957 IH 4x4...http://67-72chevytrucks.com/vboard/s...63#post8082563 2023 Chevy Z71..daily driver Last edited by mongocanfly; 01-03-2020 at 10:23 PM. |
01-03-2020, 10:38 PM | #11 |
*correction - KDA w175 2 is in the pass side, top on axle tube
01-03-2020, 10:51 PM | #12 |
Perfect thank y’all. And how about the year? Is 1965 correct?
01-03-2020, 10:55 PM | #13 |
Found these 2 holes hiding under grime. Can’t be a good sign. Is this common? Probably rusted inside right?
01-03-2020, 11:31 PM | #14 |
Its a plug weld. nothing to worry about....
01-03-2020, 11:57 PM | #15 |
Agreed...its where the axle tube is welded to the differential housing
01-04-2020, 12:00 AM | #16 |
The housing ratio Id doesn't match the r&p ratio..so I wouldnt go by that
The housing shows it used to be 2.73s The r&p is 3.73s
01-04-2020, 03:23 PM | #17 |
Yeah will most likely keep it 3.73s. It’s just gunna be a DD. Thanks a lot! Looking to order new brakes or upgrade to disk and all new r&p set. What years would be safe and any good companies to consider? CCP and Yukon are nice but a little expensive. But you get what you pay for
01-04-2020, 05:07 PM | #18 |
I'd go Yukon gears...
