The Discovery Phase Continues
Still working out kinks in 'Ol Blue... I've changed out spark plugs (they were nasty) along with wires. I also changed the in-carb fuel filter which honestly looked really clean.
She idles beautifully and does great at low speed ~35mph. If I go too fast, she will bog out and die and it's super hard to get her started again. I have a carb rebuild kit on the way... the truck sat for quite awhile so that may be part of the problem. I've run 3 tanks of fuel so it isn't bad gas but who knows what trash may have been in the tank. I don't want to drop the tank just yet. I dove into the glovebox and found the original warranty pamphlet from the dealer in 1977 along with the maintenance schedule. Nifty stuff!
"The rays of light thru the Shiner Bock bottle make me wanna turn the key and put down the throttle...and get lost down 35" - Jason Boland www.YouTube.com/user/593Films - Watch My Videos! ![]() 1977 Silverado K10 2014 Dodge Durango (Wife-mobile) 2008 Dodge Ram Lone Star Edition (Daily driver) |
Re: The Discovery Phase Continues
Check the rubber lines from the tank(s) to the frame and from the dual tank valve(if equipped) to the frame. Your symptoms are similar to what my 75 did when the original valve to frame hose started crumbling away. Air gets into the system and breaks the suction. It finally got bad enough that it died backing out of the driveway before I thought to check that out of sight hose.
Mice can also cause the same problem if they decide that hose is worth taste testing. |
#3 | |
Good call. I'll be sure to double check this... Thanks!
Could the tank possibly not be venting properly? Would cause the flow to slow down/stop until the pressure equalized again.
Tis on my checklist now... Thanks!
